70D PONY COOLING CLUTCH
Rich
04-21-2003 07:19:45
I found the problem with the cooling. I removed the top water pipe from the pony and found a chunk of silicone stuck in the top end of the pipe. The previous owner seemed to like silicone sealer better than o-rings. I readjusted the clutch, it was too tight, and the problem was cured. I learned alot. Many thanks to all for your help and e-mails.
F-I-T
04-21-2003 07:33:23
 Re: 70D PONY COOLING CLUTCH in reply to Rich, 04-21-2003 07:19:45
Rich:
Glad to hear you're up and runnin'. There are many adjustments that can be made wrong on the pony and the linkages, but when it's adjusted right, it will start the big motor any time.
Frank-in-Tallahassee
70D // 855
T-I-N
04-23-2003 14:18:03
 Re: Re: 70D PONY COOLING CLUTCH in reply to F-I-T, 04-21-2003 07:33:23
third party image
... that little pony has quite a kick when it's runnin' right! (an early 720D pony..Tedd in NE.)
