630 Brake Assembly
Greg
04-21-2003 05:52:52
My 630 has a broken bolt on the rt brake assembly where it mounts to the tractor, if I remove the remaining 2 bolts will I be able remove the entire assembly to remove the broken bolt and does this connection require a gasket.
Bob K
04-21-2003 06:23:47
 Re: 630 Brake Assembly in reply to Greg, 04-21-2003 05:52:52
Yes to both questions. Remove the other two bolts and the assembly should slide away from the tractor. There should be a gasket on the mating surfaces. If the gasket comes off in one piece, you may be able to reuse it. Deere can get them for you if you need a new one.
F-I-T
04-21-2003 06:22:20
Greg:
Yes, if it's like other models, and there is clearance to slide it out, removing those three bolts (or two bolts and a stud on some models) willl allow you to rock it loose and slide it out. There is a gasket used to keep the tranny oil from leaking out.
Frank-in-Tallahassee
70D // 855
