Hilltopper, a few things come to mind. ~I presume we are talking about a 720D pony, correct? If not, none of the below will apply. [those 24 volt systems are completely different] ~First, is the generator actually charging? It must be putting out higher than battery voltage to close those cut-out contacts...With the engine running at fast idle take a jumper wire & jump the [A] post on the generator to the [BAT] terminal on the generator. Then look at the ammeter, if it shows a charge on the ammeter your generator is charging & should close the cut-out contacts [see below]... If it doesn't show a charge on the ammeter, with [A] [post still jumpered to the [BAT] terminal add a second jumper wire to short the [F] post on the generator to a GOOD CLEAN ground. If it charges then, you have a bad regulator, bad regulator ground, or open in the [F] wire between the generator & regulator. If it still doesn't show a charge on the ammeter you have probably found your problem & that is a non functioning generator. [sorry if this is redundant & you have already verified the generator output]. ~If the generator checks out per above, you either have a regulator problem, the incorrect regulator, or a wiring problem. ~Is there a chance you have a 12 volt regulator? If so that 6 volt generator probably won't close those cut-out contacts until a very high RPM. It could be a polarization problem but you already polarized the generator when you closed those cut-out contacts to motor it. ~Is the regulator wired correctly? It sounds like you have the [BAT] & [GEN] terminals hooked up correctly or it wouldn't have motored, is the [BAT ]terminal on the regulator hooked to the power wire from the ammeter? How about the fuel gage wire? It belongs on the [GEN] terminal at the regulator [that's the one with the wire running to the generator's [A] post. The regulator [F] terminal obviously hooks to the generator [F] terminal. ~I guess the bottom line is...if the generator can & is producing at least 1 volt above battery voltage the cut-out points should close if the regulator is wired correctly, fully grounded, the correct voltage, & working. ~About the only other thing I can think of is that the regulator is not for your system polarity, but most of those regulators will work either polarity it's just the coating on the points are on the opposite point contact. Are you still running a positive ground?
