Cleaning carburator parts.(Clooney??)
AWB
04-20-2003 17:20:20
I am in the process of cleaning a JD Model LA carbutrator so that I can rebuild it. This was an especially dirty carb. Let it set overnight in oven cleaner. Then hit it with high pressure hot water. A large amount of caked on crud remained. Dissassembled carb and put into a can of carburator cleaner and left it for a week. The parts just aren't coming clean. What else can I do to get these parts clean? Any help will be gratefully appreciated. Thanks. AWB
Clooney
04-20-2003 19:02:16
 Re: Cleaning carburator parts.(Clooney??) in reply to AWB, 04-20-2003 17:20:20
AWB, are you trying to get the inside clean or just make the outside look good? You have to be careful with those aluminum carbs as the more caustic solutions will eat the aluminum.
~You might try soaking it in lacquer thinner for about a week or two....
