Paul D.....820 starting engine leak conversation
buickanddeere
01-08-2004 17:09:01
Paul, could you send your e-mail address please. It's an intersting 820, right down to the chain drive magneto rigged up where the ignition box used to be.
Paul.D.
01-08-2004 18:59:14
 Re: Paul D.....820 starting engine leak conversat in reply to buickanddeere, 01-08-2004 17:09:01
I e-mailed you my address, if you don't get it post back here and I will send it again.Also were do you live?..... .....Paul.
buickanddeere
01-09-2004 05:58:37
 Re: Re: Paul D.....820 starting engine leak conve in reply to Paul.D., 01-08-2004 18:59:14
I'll check again tonight when home tonight but suspect a glitch in the spam blocker may have tossed your letter out, sorry.
Have to look at this tractor just to see it for myself. For the custom mag drive on the starting engine and how much they busted off the pulley brake mechanism if nothing else.
Trying to think how coolant poured into the starting engine ends up in the main engine crankcase??? Will look at Dad's 80 next time home and study the parts CD. Asking price is what an intact 820 green dash goes for original with everything intact and working. Have to allow a couple of thousand+ for parts alone incase the starting engine & it's drives plus the brake needs "everything". Plus the minor items like rodents living in the seat/battery box. Plus dozens of hours just timing, clearances and sending the injectors out for cleaning. Never seen an old original set that didn't need at least cleaning and shimming the spring higher.
Link
Located in the top region of the third circle.
Paul.D.
01-09-2004 17:17:52
 Re: Re: Re: Paul D.....820 starting engine leak c in reply to buickanddeere, 01-09-2004 05:58:37
Glen, my e-mail is here on the forum.Also were did you get the parts cat. on CD? Maybe you could keep an eye open for a mechanially sound 830 up your way. That is what I really have my heart set on. Feel free to e-mail me anytime or if you want me to go and look at this tractor and take some pictures I may be able to do that ,I only live about 45 minutes away from it. I still don't understand how coolant is geting in the main engine crankcase.I looked at Brandons 2 cylinder diesel sight and there is a diagram there but I don't see how this could happen.Please let me know if you still can't get my address and I will try again..... ...Paul
