Crank leak
BottomD
04-19-2003 07:56:02
Getting a little oil coming out on my flywheel what I see in the I T manual is all I need to replace is the cork seal and left bearing cover gasket.If there is any play in the bearing would I be able to feel it by lifting up on the flywheel?Is there anything else that should be done while I got the wheel off and should I put any thing on the cork like grease or oil? Tractor A#490500 THANKS in advance BottomD.
