620 won't run through ballast resistror...WHY????
Marvin (KS)
04-18-2003 10:38:00
Tractor will start with 12V on coil (has a 6V coil)but will not run with 6V on coil. With points closed ballast resistor has 12V on one side and 4.3V on the other. I started it once with 12V directly from the battery to the coil and after it started switched to a 6V source and it DIED. WHAT GIVES???? The ballast resistor is John Deere and coil is a NAPA 6V coil with out ballast resistor. I've eliminated all the wiring with jumpers.
Clooney
04-18-2003 16:07:36
 Re: 620 won't run through ballast resistror...WHY???? in reply to Marvin (KS), 04-18-2003 10:38:00
Marvin, 4.3 volts seems a little on the low side for that 6 volt coil to function but not out of line, as a 6 volt system can drop to well under 5 volts during cranking & still start without any problems.
~Are you sure the coil is a 6 volt coil? Is the voltage written on the coil can? [if that coil is actually a 12 volt internal resistor coil it won't function at 4.3 volts period. If you have an ohm meter on your VOM, measure the resistance between the + & - small terminals on the coil, if under 2 ohms you have a real 6 volt coil, if over 3 ohms it flat won't work with that external ballast resistor.
~You might want to put the voltmeter on the coil's ballast resistor side then monitor the voltage as you switch from 12 volt [jumper] to ballast resistor supplied voltage.. The coil's supply voltage should get higher with the tractor running due to the charging system coming on line & the fact that the points should spend less dwell time at ground so the current draw should be less. [with it running the coil's supply voltage should be a little higher than the 4.3 you measured statically]
~As another test you might try running your 12 volt jumper wire to the coil side of the ballast resistor [see if it runs that way as that will test the wiring from the ballast resistor to the coil],,,then with it running simply move the jumper wire to the ignition switch side of the ballast resistor, if it still keeps running suspect the ignition switch has excess resistance [common] or the wiring from the ign switch to the ballast resistor has excess resistance.
~If the coil's supply voltage is 5 volts or over running I would suspect either a bad coil, or the condenser isn't functioning, or the distributor has a poor ground, or even fouled spark plugs.
~If nothing stands out per above you might have a mismatched ballast resistor for your coil. The ECH 1CR13 ballast resistor from NAPA [about $14.00] seems to work good with most 6 volt coils on a 12 volt system & might be worth a try. It's real hard to accurately measure the resistance of a ballast resistor due to the change in resistance from cold to working hot.
~It might be as simple as a set of partially fouled spark plugs & the higher 12 volt coil supply voltage is enough to change the coils rise time to overcome the fouling & still supply enough KV to jump the plug gap. [it might pay to try new spark plugs]
~If you can find another coil to try it might stop a lot of guessing & say yes or no to the coil as a source of the problem.
~This is a strange & unusual problem so can you tell us when the problem started? Did it just start all of a sudden? Or did you buy the tractor with this problem?
~Let us know what you find when you get it repaired?
Marvin(KS)
04-18-2003 17:27:12
 Re: Re: 620 won't run through ballast resistror...WHY???? in reply to Clooney , 04-18-2003 16:07:36
I bought this tractor and have been reworking it. The coil resistance is 1.2 Ohms, the points and condenser are new the spark plug wires are new. It is converted to negative ground and a one wire alternator. I jumpered around the switch and the ballast resistor is new from JD. I will try another coil tomorrow.
Lee
04-19-2003 03:03:51
 Re: Re: Re: 620 won't run through ballast resistror...WHY???? in reply to Marvin(KS), 04-18-2003 17:27:12
Very good info Marvin, I'm impressed and I don't say that often. According to my calculations your ballast resistor has 2.15 ohms and that is too high. It should be around 1.5 ohms for a 1.5 ohm coil for a total current of 4 amps more or less. Please verify that resistor is above 2 ohms resistance and then concentrate your efforts there.
I'm also impressed with Pertronix 3 ohm coil which needs no ballast resistor - but $30 price does take ones breath away at first. My 59 chevy has never run so smooth nor idled without missing like it does now - I'm looking for a distributor for my 43 A so that I can 'Pertronix' it too, with or without the solid state points part.
F-I-T
04-19-2003 04:51:08
 Re: Re: Re: Re: 620 won't run through ballast resistror...WHY???? in reply to Lee, 04-19-2003 03:03:51
Lee:
If $30 for a coil takes your breath away, consider the $55 for a starting engine coil, and you have to use two !
I wish there was an electronic unit for that engine.
Frank-in-Tallahassee
70D // 855
John T
04-19-2003 06:17:59
 Re: Re: Re: Re: Re: 620 won't run through ballast resistror...WHY???? in reply to F-I-T, 04-19-2003 04:51:08
Hey there Frank, speaking of pony engine coils, I was over at Bens shop last week and saw a 720 with 4 external automotive coils hanging all over it lol looked like an electricians worst nightmare. I guess it worked, just looked a bit nasty. If a person didnt want to manufacture or install any sort of magnetic pick up to trigger an electronic ignition unit, you could still use the existing points to trigger a box to fire external coils and those systems run very low current through the points so they last indefinitely. I have home made electronic ignitions Ive used on boats and other things where I usually used a Chrysler ignition box and Ford magnetic pick ups and they all worked great. I have considered taking a distributor shaft and machining magnets right into where the high cam lobes are and then using a Ford or any brand pick up coil to trigger the ignition box and then you would have full electronic and need no points at all. I love to experiment with these type of things but if you can do them so as to not alter the original appearance but improve performance, I like it even better.
Take care, John T up North of you
F-I-T
04-19-2003 07:57:23
 Re: Re: Re: Re: Re: Re: 620 won't run through ballast resistror...WHY???? in reply to John T, 04-19-2003 06:17:59
John T:
You know, I've seen those same 4 coil set-ups, but I always wondered why they didn't just use two coils and a "Y" connector to run the two plug wires to the same side plugs since that's the way it runs from the originals. Or is it that there wouldn't be enough juice to fire the pressurized plug ? So are the pony coils actually bifilar wound, like two coils in one case ?
I'd like to talk to you more about customizing an electronic box. I just think if the ponies had a sharper spark it would help all the way around. Even if it meant going to 12 V it wouldn't be all bad. I think it might help get a round the posible fouling that comes from engines that are most often started cold.
I'll do some internetting and maybe start another thread up above and you can give me some advice.
Thanks again !
Frank
Clooney
04-19-2003 10:06:20
 Re: Re: Re: Re: Re: Re: Re: 620 won't run through ballast resistror...WHY???? in reply to F-I-T, 04-19-2003 07:57:23
Frank, the best working non-production set-up seems to involve using GM or Ford lost spark coils as they have 2 plug wires exiting them & produce about 40,000 volts at both plug wires. The only problem is point life as those coils run at better than 5 amps each. Those coils use the same basic system as the original Deere & use one plug for each side of the coils secondary so one fires positive & the other fires negative. They do need 12 volts to function though.
~The problem with 4 separate coils is the current they draw & point life, not to mention complexity. ~Using 2 automotive coils & a Y connector will probably only get the easiest plugs to fire [& that will probably be the one without compression], there isn't much extra left for the other plug after the easiest one fires.
~I have converted a few over the years to the GM lost spark coils & those babies will produce a spark that will jump a 3/8" gap & plug fouling doesn't seem to matter....
John T
04-18-2003 13:03:24
Good afternoon Marvin, To begin with, that 4.3 volts on the low side of the ballast which is the coil voltage is tooooo ooooo ooooo o low. The coil is designed for 6 volts, and if the voltage on it is only 4.3 cold, it will be even worse after things warm up. Sounds like maybe the ballast is too much resistance, either from manufactured too high or has become bad with age?? If the coil is to see 6 volts after the ballast and coil is warmed up, the ballast resistance would be near the same resistance as the coils primary winding (between lil + and - terminals). That way, you have an equal resistance load voltage divider which will drop 6 volts across the ballast leaving 6 across the coil as designed for.
Measure the DC resistance of the coil primary and the ballast and Im afraid the ballast will be considerably higher, when it should be near the same or slightly less????? ????? ???? The coils primary resistance should be near or slightly less than 2 ohms if its really a 6 volt unballasted unit.
On a 12 volt tractor that uses a 6 volt coil and a ballast resistor which is equipped with a ballast by pass starting circuit fed off the extra lil terminal on the side of the starter switch, they are supposed to start (when engine cranking) with full battery voltage on the coil, and then the coil voltage drops to 6 to 8 (depending on ballast size) volts (not low like 4.3) because the voltage dropping ballast is back in the circuit.
Now, why it wont run after started if you put 6 volts on the coil is a bit tricky. If its really a 6 volt un ballasted coil, 6 volts across it should allow sufficient current flow through it and the points to fire the plugs. I assume the ballast is fed 12 volts from the ignition switch, and its output side leads to the coil. The output side of the ballast or the high side of the coil (same electrical point) should have the extra start by pass circuit wire up from the start switch which is battery voltage ONLY when starter is engaged.
Here are some things in question as to why it wont run with 6 volts on the coil:
1) Youre sure its a 6 volt un ballasted coil?? if it had an internal ballast and its polarity were wired wrong, it causes a weaker spark. Resistance should be near 2 or less.
2) What ground are you running, pos or neg, and is the coil wired the same????? ? i.e. if pos grnd as original, the coils + goes to the distributor.
3) When you hot wire jump around the ballast, how are you doing that???
4) If you jumper wire around the ballast direct to the coil from the ignition switch output with it on, whats the voltage on the coils high (non distributor) side when points are closed ????? ????? Im looking for any internal switch resistance via this test.
and with the jumper on will it start and continue to run????? ? (dont run it very long) If its really a 6 volt coil, it should start and run that way, but the coil will get warm as its drawign more current than designed for.
5) Do you suspect the ignition switch?? They can go bad and create an internal resistance wherey by they may show correct voltage (with a good voltmeter) but under a load drop voltage causing low coil voltage.
Heres some other things to try:
Try a direct jump hot wire from the battery (by passes any bad switch) to the ballast input and see if she starts and runs. If it does, I suspect the switch. If it dont, the ballast could be too much resistance as originally suspected.
If she wont start that way, run the direct hot wire from the battery to the coils high (non distributor) side input and see if she starts n runs. If so but she wont via the switch, again the switch may be bad.
NOW, place a jumper wire around the ballast (to by pass it) and see if she will start either if fed from the switch (original wiring) or hot wired to the ballast high (non coil) side. Then once shes running, remove the ballast by pass wire and if she then dies, I suspect the ballast is again too much resistance.
That should be enough to get troubleshootign started, so give her a whirl and see what happens and post back the coil and ballast resistance and the voltage measurements and polarities and hopefully we can get her going. I still question the coil and ballast resistance and possibly a bad switch or switch wire might be a problem. Also, perhaps if the points or condensor were bad, it might cause a situation where 12 volts makes her run, while 6 (especially 4.3) will not. Take a look at the points and check the gap plus clean them if gray oxidized or replace them if burned or pitted or carboned up badly. You might also remove the plugs and with their wires attached and them up aghainst the frame, try the above by passes and tests and see if and when you get or dont get a good blue spark across their gaps.
Good Luck God Bless the USA, please pray for our troops. Ol John T Nordhoff in Indiana
Marvin(KS)
04-18-2003 17:35:59
 Re: Re: 620 won't run through ballast resistror...WHY???? in reply to John T, 04-18-2003 13:03:24
Noting worked I am going to try another coil tomorrow.
John T
04-18-2003 20:53:18
 Re: Re: Re: 620 won't run through ballast resistror...WHY???? in reply to Marvin(KS), 04-18-2003 17:35:59
Good Luck Marvin, In that whole ignition primary side circuit about all you have is an ignition switch, ballast resistor, coil, points and condensor, so if the ballast resistance hot or cold is okay, what youre gonna try (the coil) should narrow down the possible causes of the problem, assuming the wires and grounds are good.
Let us know. John T
