JD 1010 cross reference
Jon
04-18-2003 07:34:30
I have JD 1010 RC w/power steering believe to be serial #31000/up .Also i have someone looking for power steering cylinder for his 58'JD 420 #129782....A couple of different listings shows me 420 chassis parts are interchangeable with 1010 parts.Is this true?Up to what serial numbers does it include?Will a steering cyl from late model 420 fit into a later 1010?Any help would be great!Thank you
G Taylor
04-19-2003 08:08:35
 Re: JD 1010 cross reference in reply to Jon, 04-18-2003 07:34:30
To ID which serial number range. Where is the gearshift and is the handle bent or straight? Is the transmission's casting front bolt pattern use 4 or 7 bolts/studs. Is there a rectangular plate held down with six bolts on the transmission/final drive casting under the seat? Are are hydraulics low or high pressure. To figure out which chassis, are the finals drive reduction gears mounted inboard or outboard?
Not sure, but lets talk 1010
04-18-2003 10:51:35
I am interested in the fact that you have power steering on your 1010. I have a 1010 RU without power steering. A number of people have commented that 1010's don't have a lot of power at low rpm's, and I find that to be true with mine. That makes me wonder how well they work with the added load of power steering. Any problem with adequate hp on yours?
Jon
04-18-2003 10:58:32
 Re: Re: JD 1010 cross reference in reply to Not sure, but lets talk 1010, 04-18-2003 10:51:35
I do not how the power steering works into driving the tractor,the tractor does not run.
Loren
04-18-2003 11:04:18
 Re: Re: Re: JD 1010 cross reference in reply to Jon, 04-18-2003 10:58:32
Okay. So are you looking for parts to make it run or parting it out?
Jon
04-18-2003 21:15:52
 Re: Re: Re: Re: JD 1010 cross reference in reply to Loren, 04-18-2003 11:04:18
I'm not looking to fix it,I was seeing if one of the parts on the 1010 could be used on someones 420
JDknut
04-18-2003 09:10:43
The 1010 chassis was supposed to be essentially the same as the 420/430, and I have heard that some of the parts are interchangable.
G Taylor
04-18-2003 15:36:22
 Re: Re: JD 1010 cross reference in reply to JDknut, 04-18-2003 09:10:43
If armed with the 1010 parts manual and the JD two cylinder parts CD you can cross refernce what parts mix and match.Otherwise don't try. The greatest amount of cross over occurs from the slant steer 420's/430's and the 1010's up to serial number 31,000 of the same chassis style.
