630 Hand Clutch hard to engage
JayDee
01-08-2004 15:24:40
I am having a hard time engaging the clutch on my 630. I have to push forward on the clutch lever very very hard in order for it to snap into place. Once into place the lever will stay put until pulled back out. Is there anything I can do to make the clutch snap into place much easier?
Clooney
01-08-2004 15:46:50
 Re: 630 Hand Clutch hard to engage in reply to JayDee, 01-08-2004 15:24:40
JayDee, if the clutch has always worked good, then all of a sudden the lever became hard to snap in just use the clutch a while & see if it gets better [sometimes those lined disks swell up from a little moisture & make the clutch harder to snap in]..
~Your other option is to back the 3 clutch adjuster nuts off a notch or two & see if it gets better..
~If the use or adjustment doesn't make it better then you have something going wrong inside the clutch pulley like wear or a broken disk..
~If you suspect an internal clutch problem post back for a rather long list of things that could be wrong or things to check..
[email protected]
JayDee
01-10-2004 16:33:38
 Re: Re: 630 Hand Clutch hard to engage in reply to Clooney , 01-08-2004 15:46:50
Clooney, Thank You. I will try this out and see what happens. Thanks again for the reply.
