720 Won't shift
Randy
04-17-2003 19:42:18
Tranmision won't shift into 3rd or 6th they are on the same shaft the gears all worked just fine untill i had to put a bearing in and had to remove all the shaft Please Help my john dealer can't tell me whats wrong
Clooney
04-18-2003 05:36:23
 Re: 720 Won't shift in reply to Randy, 04-17-2003 19:42:18
Randy, when you say 3rd-6th it sounds like you might have the optional 2nd-5th gear set transmission. [Are 3rd & 6th directly across from each other with 2nd in the upper L/H slot?]..The gear position makes a big difference in what your problem might be.
~Next, you say it won't shift into those gears. Does the shift lever move into the slots or does the lever hang & not actually move into the quadrant slots. ~Answer those questions then send me your E-Mail address I'm.. [[email protected]] & I will send you a picture with red arrows showing the possible problem areas..
Randy
04-18-2003 19:49:36
 Re: Re: 720 Won't shift in reply to Clooney , 04-18-2003 05:36:23
Yes my 3rd & 6th are straight across from each other &2nd in upper L/H slot. The shift leverdoes not move in the slots at all on 3rd & 6th
Clooney
04-19-2003 05:33:53
 Re: Re: Re: 720 Won't shift in reply to Randy, 04-18-2003 19:49:36
Randy, see the E-Mail I sent you for a picture of places to look at.....
Randy
04-19-2003 10:55:30
 Re: Re: Re: Re: 720 Won't shift in reply to Clooney , 04-19-2003 05:33:53
thanks for the photo. I'll look it over today and see what i find Thanks
