JD 70 problems
fuzzy
04-17-2003 17:43:01
I have a '55 JD 70 it will start at idle and putt putt just fine but when you add the gas it dies just like you shut the switch off. when you return it to idle she runs fine. any thoughts
Clooney
04-18-2003 17:34:12
 Re: JD 70 problems in reply to fuzzy, 04-17-2003 17:43:01
Fuzzy, it sounds like you might have something plugging your carb load system, or a lack of fuel flow to the carb. Open the carb drain plug, then unscrew the knurled nut on top of the fuel strainer & hold the valve open, you need to have a pencil sized stream of fuel flow for at least 30 seconds [if not find out why as you have probably found your problem].
~If the fuel flow tests out ok you probably need to remove & clean the load nozzles in the carb. ~It could possibly be the a lean set load screw but if it ran good before & the screw hasn't been turned in tight by you or someone else that probably isn't the problem.
~If you are getting black smoke out of the exhaust stack when the problem occurs post back for other options....
70d larry
04-18-2003 16:24:34
It sounds like you have your load screw ajusted wrong. Have you try playing with it? Good luck larry
