Clooney B teardown question
Chris
04-17-2003 16:38:36
clooney i am reringing my 39b. What are the torque specs on the rods and on the head and also it was not knocking and i kept the shims where they were when i took it down so do i need to check the clearance on the rod shims or just put it back together if i do how do i check it and set the shims right. Thanks Chris
Clooney
04-18-2003 05:27:11
 Re: Clooney B teardown question in reply to Chris, 04-17-2003 16:38:36
Chris, I don't have any firm rod or head bolt torque specs on the 39 but I have 63 ft lbs penciled in my little book for the rods & 96 ft lbs for the cylinder head. I don't have a manual where I'm at now so maybe someone can double check those numbers for you.
~While you have it apart you really should check the rod bearing clearance. You really can't use Plasti-Gage on a used worn 2-cylinder crank as the crank wears egg shaped. The best method I have found is to install one rod/with piston [no rings] at a time [oil the piston & bearings], then start turning the flywheel to get a feel for the turning resistance, then remove a shim [evenly from each side] & re-tighten the rod cap [just fairly tight, you don't have to torque it], keep doing this until a light drag is felt on the flywheel, then install one .003" shim on each side of the rod, that should put you real close to where you need to be. Turn the flywheel slowly & smoothly & feel for the tight spots [that's where what you want to set to, the tight spots] Then REMOVE that rod/piston & do the same on the other side.
~While you are in there make sure the piston pins aren't loose in the rod or piston [a common problem].....
