Cylinder markings
Andrew
04-17-2003 16:21:43
I have a 620 gas with the motor apart. The piston rings still appear to be in good shape. But when we took the motor apart, we forgot to mark which cylinder each piston and rod came out of. My service manual says that there is a marking on the piston or rod, indicating which cylinder each piston and rod goes in . We have looked at the pistons and rods several times, but cannot find these markings. If somebody could please tell me where these markings are I would really appreciate it. Thanks
Larry806
04-17-2003 18:44:14
 Re: cylinder markings in reply to Andrew, 04-17-2003 16:21:43
Look at where the rod cap bolts on there should be a no 1 on the cap & matching rod that line up The other should have no 2 on it. The no.'s go to the top when instaled Hope this helps Larry
