Bill, there might be a very simple solution. That depends of if I understand your question correctly.. ~If I understand your question correctly your 3-way valve leaks when you shut the fuel shut-off valve at the strainer.. If that is the case just close the strainer shut-off valve, then run the carb out of fuel when you shut the tractor down, then just leave the carb drain cock open.. What happens is fuel gets trapped between the strainer shut-off valve & the carb needle & when the ambient temperature changes the trapped fuel expands & forces it's way out of the 3-way valve packing. Sometimes a new 3-way packing will help or adding a second brass washer over the strainer packing but that pressure can build pretty high in that fuel line [that's just a cork packing not a real lipped seal or "O" ring] ~If I don't understand your question correctly & you are trying to shut the fuel off with the 3-way valve DON'T, use the strainer fuel shut-off valve.. The 3-way is only for diverting fuel from either the starting tank or main tank & not used as a shut-off valve.. Problem is, those barrel type strainer shut-off valves don't work too good after years of use so that might not be working correctly. If that strainer barrel valve is not working correctly it is hard to repair.. You can replace the entire strainer or if you are creative you can install a small 1/4 pipe thread, tapered seat shut-off valve between the 3- way valve & the strainer.. If a small valve is used & the 3-way is modified you can hardly see that added valve between the strainer & 3-way.. That positively stops the fuel flow... ~On your MT Wayne has the answer.. ~If I mis-read your question post back & clarify your problem a little more... [email protected]
