John Deere 4230 hydraulic hose chatter- power sterring problem
terry
04-16-2003 17:47:46
I am looking a buying a 1973 JD 4230 with 9000 hr and a Leon front end loader. Inspection reveiled 3 problems that concerned me because of possible high cost to repair them. The main problem is that when raising or lowering the lift the hyd. hoses to the cylinders chatter/jump quite a bit, like water hammering in pipes. This happens at any engine rpm or any tempeture and thu the entire lift cycle up and down. When going down the opposite side hyd. hose chatters. The hyd. valves of the lift are plumbed direct into the hyd.. supply line below the floor pan with 1/2" hose or the same size as the other hyd. lines. The return line is 3/4" and dumps direct into the transmission case. The hyd. pump makes no noise, and the coupler appears secure. If the lift valve is cracked open a small amount there is no chatter, only when going to 1/3 open or more dose the lines chatter with it getting worse full open. A related problem is after starting the engine I can turn the front wheels all the way to the left-no problem but can only turn them to the right 3/4 of the way where the stop. If I turn them back left all the way then to the right they go futher- say 7/8 of the way. I do this 3-4 times then the powerstering acts normal. Whill doing this they move smoothly. What could be the problem and fix?
Problem 3 is transmission oil leaking at the gasket between the engine and transmission housing at the bottom bolt- a slow drip. Any way to seal or stop this? Dose transmission sealer work on something like this or is that a no-no?
Thanks
Terry
davidval
04-17-2003 02:46:24
 Re: John Deere 4230 hydraulic hose chatter- power sterring problem in reply to terry, 04-16-2003 17:47:46
first,make sure the loader valve is ok: disconnect return line at valve and start engine. there should be no oil flowing out of the valve with all levers at center.
if that's ok, connect the return line to the tractor's return system. this way return oil flowes back to the main pump and prevent starvation.(especially due to low transmission pump output into the main pump.
you probably have the older style steering system on your tractor, if so your steering valve is most likely the cause for the steering problem. it should be rebuilt and adjusted correctly.
as for the leak at the bottom: best thing to do is to replace the gasket and check alignment of oil pan with the cylinder block at the gasket face. you can also remove the oil pan and make a gasket for it's rear face to replace the existing bottom part of the clutch housing gasket. chances are you will not achive absolute sealing this way.
david
twopop
04-16-2003 19:56:53
not sure about your power steering problem,but, your main hyd pump probably needs to be rebuilt.I believe some of the valve seats are leaking
