JD 855 headlight
Doc
04-16-2003 12:19:38
I have an 855 compact tractor with a burned-out headlight. It is a GE H9064. Can't find this anywhere. Local JD dealers want $32 for the lamp and the housing - can't sell me just the lamp. This seems ludicrous as the lamp should be about $8 at the most. I've been to auto parts stores and the local Farm N' Fleet. I even called GE and they said yes, we make that bulb, but can't supply it to you. This one really galls me. Any ideas on a source? Thanks.
Mike OH
04-17-2003 17:58:12
 Re: JD 855 headlight in reply to Doc, 04-16-2003 12:19:38
Hi Doc- I had to replace one headlight on my 855 this spring. Seems as though the glass cracked which I suspect was due to the heat of the lamp and contact with snow and ice while I was blowing snow this winter. My local JD dealer had one in stock (part No. AM102023) and charged me $24.00. I thought that was high also, but was better than what they wanted to charge you. I think I'd check with another dealer. Good luck.
