JD 60 does not get gas
charlie
04-14-2003 19:28:41
Last year I put new rings and pistons in my 60 and i did a value job. The tractor started after the overhaul last october and I ran it 3 or 4 hours . I then put it in storage for the winter. Now i go to start it and it won't fire. I pulled the plugs and they are not wet with fuel. I am getting a good spark, but there is no fuel getting to the plugs. I did a compression check and each cylinder has 92lbs, so i assume i have vacumn enough to draw gas. I took the carb off and it looks wet in the throat so i assume its geting gas. What else can i look for? The small screw at the bottom on the carb bowel, what effect does that have on the carb? How do you adjust it?
Clooney
04-15-2003 03:57:46
 Re: JD 60 does not get gas in reply to charlie, 04-14-2003 19:28:41
Charlie, that small screw on the bottom of the carb is the load screw & is adjusted to allow the engine to pull good under load & still get decent economy. It can effect the running under load but shouldn't effect the starting.
~First, are you sure the carb is getting a GOOD SUPPLY of gasoline? Open the carb drain valve & look for about 4 oz. of fuel to come out, then unscrew the knurled nut on top of the fuel strainer & hold the knurled nut down for about 20 seconds, you should be getting a stream of fuel out of the carb drain as long as you hold that knurled nut down [if not you have a blockage in the fuel system somewhere]. If you are getting a good fuel supply to & through the carb, re-check the spark with both spark plugs still in the engine & install another plug in each plug wire for a test for spark [sometimes the compression load on the starter will lower the system voltage enough to weaken the spark].
~It wouldn�t hurt to install new spark plugs just to eliminate that as a cause of your problem.
~The usual cause of a tractor not starting after sitting for a while is oxidized points, followed by gum or rust build up in the carb. Take an old [known good] spark plug & open the gap to 3/16�, then install that in one plug wire at a time & lay on the block, then crank the engine, you need a blue spark to jump tat 3/16� gap for the engine to start. If you are getting a good blue spark suspect the carb being gummed up inside.
