JOHN DEERE-H INNER FRONT WHEEL BEARING
GERRY
04-14-2003 10:44:49
HOW DO YOU REMOVE THE INNER FRONT WHEEL BEARING?
THERE ARE TWO FELT WASHERS AND A SHEET METAL FLANGE INSERT THAT LOOKS LIKE IT IS PEENED IN THE HUBAND I WOULD HAVE TO DESTROY TO GET IT OUT TO REMOVE THE BEARING AM I CORRECT.
Frank M.
04-14-2003 18:04:51
 Re: JOHN DEERE-H INNER FRONT WHEEL BEARING in reply to GERRY , 04-14-2003 10:44:49
Here's how I pull the seal and inner bearing. Remove the nut and outer bearing, then screw the nut back on the spindle a few turns. Slide the hub out til you feel the bearing contact the nut. Push it back in just a little then give it a sharp yank. Bearing and seal will stay on the spindle. This is much quicker than trying to drive them out with a punch. Also it doesn't damage them. I was taught this trick almost 30 years ago, and haven't had it fail yet.
Hope this helps
Frank M.
phil
04-14-2003 11:58:15
Gerry, you shouldn't have to destroy the shields. I disassembled mine & repacked them a couple years ago. I recall the felt washers & the peened shields. I tapped them out with a drift from the far side, washed them up, & reused them.
