70D : Pony carbon fouling plugs
F-I-T
04-14-2003 07:17:57
third party image
My pony has not been acting right lately, and I thought I might have a major problem. It was beginning to backfire, and not starting well, not running smooth at all. Well, I guess it's been a while since I really worked around a spark engine, so I finally pulled a plug and it was terribly carbon fouled. It has been had a ring job, and there is no oil involved.
I cleaned the plugs and it fired up and ran very well. That is for a maybe several minutes. Then it began to pop a bit, and began to lose speed, until it would die. I added a jumper to give 6 volts direct to the coil (just for a test !), and it picked up speed. Once it was back at top end, I could cut off the jumper and it would run on the reduced voltage.
I started the main engine and warmed everything up really well. Then I started at the timing, and it is right on. Points are new and set to .020". The plugs are clean and gapped at .025"
I shifted it to crank the diesel on full compression, and slowly turned in the load screw. The engine began to slow, so I began turning the load screw out. I had to come out a good 3/4-1 more turn to get it stay at speed at load. I think it likes to be 1 1/2-2 turns, which seems like a lot. I ran it for a while, and it ran out of fuel (from a full tank). I know they are not misers, but it really seemed to be using a lot of fuel for the task. Then I pulled out the first plug, and it is clearly carbonning up again, after just a few minutes run (see the picture). Air cleaner is clear, timing is right, ignition parts are new.
The last plugs I bought were NGK's, B6S. Guess I'll set out find the called for Champion J8C.
Questions are:
Would the next hotter plug be helpful ? My Champion chart shows the next hotter plug as J19LM, and then the hottest as J11C, or RJ12C in a resistor.
Anyone else have pony's that run this rich, or what might I do to solve this.
Looking for things to try. I don't want to put the hood back on until I have this figured out. BTW, any good way to change that plug the sits behind the lower left corner of the dash ?
Frank-in-Tallahassee
70D // 855
Ty
04-15-2003 04:50:27
 Re: 70D : Pony carbon fouling plugs in reply to F-I-T, 04-14-2003 07:17:57
Frank I use Autolite plugs I can't think of the number maybe 386. Jeeez Frank sorry for all of your troubles. Mine still works great. I also had a lazy gen. put a new belt on A-43 Gates belt. Not happy how JD belt lasted and seems to be kinda cheezy made. I worked land w/ it last night 12ft. vibrashank 24 teeth 7" sweeps. I have a hayfield and put it not all the way the first time but on the second pass. She was LUGGING!! Talk about power holy cow even on a 6 yearold hayfield. Hope you get your pony back to norm!
F-I-T
04-15-2003 05:55:19
 Re: Re: 70D : Pony carbon fouling plugs in reply to Ty, 04-15-2003 04:50:27
Ty:
I used to use Autolite plugs on my '48 "A". They are manufactured at the plant in Fostoria, Ohio, where my wife is from. We lived there for 20+ years. My old "A" had a lot of Autolite engineering test plugs in her. Everytime I hear folks sing the praises of Autolites, I feel that ole' #595751 played a goodly part in the R&D. 25 years ago those plugs were so bad we used to call them "Ought to lite". They'd hardly fire in an old JD.
As of this morning it starts and runs fine. I am curious that I may be lossing voltage as the pony coils heat up. After a good warm up, you can hear it begin to stumble, and if I put 6 volts straight to it, it picks right back up. Maybe I have a high resistance connection, and as the pony runs, the current draw increases, and the wire resistor on the switch increases in resistance. I'll find it.
My multimeter must have too fast a sampling rate, because it can't seem to pick up a solid voltage reading. I going to have to borrow back my old Triplett analog.
Curious.
G Taylor
04-15-2003 19:31:22
 Re: Re: Re: 70D : Pony carbon fouling plugs in reply to F-I-T, 04-15-2003 05:55:19
If the digital multimeter has a manual scale select then set it to one of the highest voltage ranges. Takes the dance out of the display for most applications. Have to purchase a new one myself. My Radio Shack multimeter went senile just after the warrenty expired. Some of the Meterman units now built by Fluke look pretty interesting. One of these days I'll find and purchase the classic Simpson 260 analog meter.
Blksmok
04-14-2003 11:38:33
Frank....Is there a possibility that your ignition switch (bad contacts inside the switch)and the resistor terminal on it are not allowing enough voltage to the points during the "run cycle"? I find this to be a common problem if you're still using the orignal, uncleaned switch.
It sounds like everything else is new and checked out. Just a thought.
On the difficult plug, I use a box end wrench that has dog leg in it that allows it to get on the hex portion of the plug w/o the rest of the wrench hitting the cylinder head. I put "never-seize" on plug threads so once I break it loose I can turn it out by hand. Still not an easy job, but I know it can be done this way.
BTW...F-I-T
04-14-2003 12:35:26
 Re: Re: 70D : Pony carbon fouling plugs in reply to Blksmok, 04-14-2003 11:38:33
I went ahead and ordered a new switch...
It'll be in Wednesday. I'll let you all know.
Now I'll go out and install my new J8C's.
F-I-T
F-I-T
04-14-2003 12:21:52
Bruce:
I was leaning toward the "low voltage" premise myself. That would explain why the plugs foul more easily, and why the engine comes back up when I nudge the pedal enought to kick-in the by-pass line. I had taken that switch apart and cleaned it before, but maybe I'm in the market for a new one...I hope it's available. You know, for now, I could put a separate toggle switch on the side where to test it with. I have a spare resistor....H-m-m-m-m-m-m-m ?
As far as that plug goes, I can't even get my fingers on it. I thought I had done that before when the cowl was on, so I must be missing something.
Frank
Clooney
04-14-2003 09:28:11
Frank, make sure the plug wires are fully inserted in the coils. Try the J-8C, I've had real good luck with those copper plugs.
~Every other plug in those little beauties fire reverse polarity so those plugs tend to foul easier. Those little engines don't have real good oil control so don't use a synthetic oil as that can get into the combustion process & foul plugs easier. ~I have found that taking an old cheap pressed tube type plug socket & cutting it off at about the top of the hex will just slide over that L/R plug & allow a box end wrench to get a bite on that cut down socket & get that plug out quite easily.
~For what it's worth I have to run my pony carb's load screws open farther than the book says.
~One last thought, you might want to reach in the #1 plug hole with a pencil & touch the piston, then rotate the pony flywheel to try & find actual TDC. Those pony ring gears will go on anywhere & unfortunately the timing mark is on the ring gear [your timing mark might be off]....
F-I-T
04-14-2003 10:00:43
 Re: Re: 70D : Pony carbon fouling plugs in reply to Clooney, 04-14-2003 09:28:11
Clooney:
Thanks for the recommendations. Some info:
- make sure the plug wires are fully inserted in the coils.
FWIW, when it quits, both coils quit. It's not like just like one pair of wires misfires.
- Try the J-8C, I've had real good luck with those copper plugs.
I'll head out for asome this afternoon. You don't think a hotter plug is worth a try ?
- Those little engines don't have real good oil control so don't use a synthetic oil as that can get into the combustion process & foul plugs easier.
I've been using 10w30. In fact the Rotella the main engine uses. The plugs don't look oil fouled, just dry carbon. She's running really rich.
- I have found that taking an old cheap pressed tube type plug socket & cutting it off at about the top of the hex will just slide over that L/R plug & allow a box end wrench to get a bite on that cut down socket & get that plug out quite easily.
Good idea !
- One last thought, you might want to reach in the #1 plug hole with a pencil & touch the piston, then rotate the pony flywheel to try & find actual TDC. Those pony ring gears will go on anywhere & unfortunately the timing mark is on the ring gear [your timing mark might be off]....
I'll check this out, but the distributor seems to be in what I would consider a "normal" position. Also, not sure, but I think I checked that timing mark position when I was re-assembling it...I usually do. Should a guy try a little more advanced to get it a bit hotter ?
I'll keep you posted after I install new plugs.
BTW, I think the charging is fine, but it really does need a new fan belt. I had a new one for it, and mislaid it while it was torn down, so I put the old one on it, and I think it is just too old, too stretched, and too slick. It full-fields fine !
Frank
Clooney
04-14-2003 11:26:59
 Re: Re: Re: 70D : Pony carbon fouling plugs in reply to F-I-T, 04-14-2003 10:00:43
Frank, any chance that oil pressure switch is acting up?
~I don't know about hotter plugs, I have had real good luck with the J-8C. You could always go hotter if you have to [or add 2 plug gaskets as that will raise the heat range a little]
~I don't know about advancing the timing? I had a pony on a 70 a few years ago & that pony ran great. It started good, had good power & revved like no tomorrow. I gave it a tune up & set the timing BACK to factory specs & it didn't run nearly as good. I don't know how many degrees it was advanced but probably about 3/8"-1/2". I always meant to set it back a little advanced & never did. If you only crank your diesel a few revolutions & start it right up it probably wouldn�t hurt to advance it a little, but if you do like me & use the pony to motor the tractor out of the barn before firing so the smoke goes outside the barn you wouldn�t want to stick a ring or burn a piston [those little pistons are quite fragile]�
Status report F-I-T
04-14-2003 13:47:57
 Re: Re: Re: Re: 70D : Pony carbon fouling plugs in reply to Clooney, 04-14-2003 11:26:59
CLooney:
First thing I checked was the resistance thru the OP switch. It's fine. The new J8C's made a MAJOR difference. Runs like new. It allowed me to really lean out the load quite a bit, and the idle a bit, too. It spins the diesel very well, and doesn't get that loading up it had before. Now that it's warmed up, I'm thinking I should let it scream for a while cranking the diesel to maybe blow some of that carbon out of there. That's what I'd with a large engine, put it on a load and let it go.
Bad idea ?
I don't know, I guess that those NGK's might have been the problem. I know folks swear about specific brands in specific applications.
Anyway, did you know that those J8C's are "small engine" plugs ? NAPA guy told me those were used in quite a few lawn mowers.
One more thing. A Tecumseh 6 hp tapered paper air filter will just slide into the pony inner air cleaner baffle just snug. I'm thinking of trying that for a while. I don't like the oil that can slop around and get all over the pony. I'd put piece of wire mesh in the outer baffle to keep any of the oil that the diesel might vent away from the paper element. I wouldn't think it would be much. Mostly fumes. The rate that I run it it should last for years if it doesn't get wet or oily. Then I could find another aircleaner pan, drill a hole in it and route a small line down and away if there was any drippage.
Bad idea ?
Frank
Clooney
04-14-2003 15:27:02
 Re: Re: Re: Re: Re: 70D : Pony carbon fouling plugs in reply to Status report F-I-T, 04-14-2003 13:47:57
Frank, yes those J-8C plugs work in most small lawn type engines so the price is quite favorable.
~On that air cleaner, let me know how it works, I have my doubts you will be happy with that paper element for long term use as the big diesel crankcase vents through the pony air cleaner..
G Taylor
04-14-2003 08:03:12
That often ignored rear left plug is often the reason for the out of sequence diesel starting on a three cylinder starting engine. Flying inertia starts or starting with the fuel already injecting before applying compression are often seen rather than getting the starting engine up to full HP. That &^^%$#@ plug will come out with some patience, removing the right plug 1st and of all tools just a open and box wrench with lots of fiddling. I have been tempted to use a hole saw and make a socket access hole in the platform. As for the fouling, that problem has went away sometimes just with fresh fuel from a busy gas station. How old are the plug wires? There are two different coil to plug wire connection methods. I did one time end up with plain wires and spring loaded coils together. Makes for 2 extra gaps for the spark to jump.
F-I-T
04-14-2003 08:28:22
 Re: Re: 70D : Pony carbon fouling plugs in reply to G Taylor, 04-14-2003 08:03:12
G:
Wires are very good. I put in an entire "kit" from Magneeders when I first got it done here. I did replace the coils once, so I'll look inside of one and see if I have a different connection method, but I thought that it was that little double clip that clips onto the wire end almost like a spark plug boot and terminal.
I'll look at anything at this point. It had run so well, that now I am determined to track it down.
As far as that odd plug, I guess I'll just lift the steering support up and get it out.
Frank
