How to remove clutch drive disc JD B with stripped jack screw holes
Tyler, MO
04-13-2003 18:39:06
My 51 JD "B" needs the clutch bearing packed with grease or replaced. I was attempting to remove the clutch drive disc and came to realize that the jack screw holes are stripped out! I could possibly use a gear puller...however I need to move the wheel out. I am a bit concerned that when I do this I would break the clutch drive disc?? Does anyone have ideas on what to do. I'm not sure about drilling and tapping those holes out to 9/16 and still be able to clear the gear teeth on the disc. What about a self expanding bolt(like one for concrete walls)? Any ideas would be great! Thanks
Tyler
ChuckW
04-14-2003 20:01:43
 Re: How to remove clutch drive disc JD B with stripped jack screw holes in reply to Tyler, MO, 04-13-2003 18:39:06
I believe I would get a threader just over the stripped hole size and rethread....don't drill out the hole. I believe this would work.
