JD B Alternator Conversion Successful
Jeff
04-13-2003 16:26:37
Thanks to everybody who helped with advice in putting an alternator and 12 volt on my B. Sure is nice to just hop on and fire it up without running around opening and closing the petcocks. Here is a picture of the ole girl earning her keep putting up a post to shore up the barn foundation. Ran out of gas just as the post dropped into the hole. Guess I'm done for the day : ) Check out my "bolt on the side on the frame run off of the flywheel live hydraulic pump" and my tossed together three point set up : ) The ole B isn't pretty but don't know what I'd do without her. third party image
troy davis
04-15-2003 08:20:03
 Re: JD B Alternator Conversion Successful in reply to Jeff, 04-13-2003 16:26:37
could you please send me what information you received on the 12 volt conversion. I would really like to get my ole johnny B running. thank you for your time. Troy
Jeff
04-16-2003 11:07:36
 Re: Re: JD B Alternator Conversion Successful in reply to troy davis, 04-15-2003 08:20:03
Just put a post here asking for it. Clooney set me up with a complete step by step instructions including part numbers and everything.
