2010 Gas waterpump pulley
Dave / Believer
01-08-2004 07:28:28
I bought a waterpump pulley off eBay with a part number T422T followed by JD stamped in the cast pulley. I posted some time ago and someone with an old parts list said that part number was for an oil pump housing. The box the part came in (original John Deere box, two legged deer) also has T422T and FAN HUB 60803 stamped on the box. Can anyone verify this part number for me? The current part number on JD PARTS web site is T14593. It looks right but the center hole where it mounts to the water pump shaft is straight machined with no keyway.
By the way, I paid $17.75 with shipping included, my dealer wants $144.00 plus for it if he can get one. I figure it was worth a try.
Thanks -- Dave / Believer45
Tom in Mo.
01-08-2004 19:05:34
 Re: 2010 Gas waterpump pulley in reply to Dave / Believer45, 01-08-2004 07:28:28
Hi Dave, My parts book for the 2010 says the water pump pulley or 'sheave' is T14593. My pump pulley is original and is steel, not cast.
I looked thru my other parts books and didn't see any T number with less than 5 digits.
Dave / Believer45
01-09-2004 01:32:33
 Re: Re: 2010 Gas waterpump pulley in reply to Tom in Mo., 01-08-2004 19:05:34
Thanks for taking the time to look it up for me. My pulley may or may not be original but is cast with a couple small chunks out of the pulley portion. I guess I'll find out when the weather breaks and I can pull the old one off. Looks like I may have to pull the radiator or water pump to do it though - I think it will require a puller to get the old one off and there is not enough room to do it in place.
Dave / Believer45
Dave / Believer45
01-09-2004 16:58:19
 Re: Re: Re: 2010 Gas waterpump pulley in reply to Dave / Believer45, 01-09-2004 01:32:33
Thanks for the tip, jdemaris - I will be sure to pull the water pump to do the job. Looks easier than the radiator anyway. If it is a press fit maybe I do have the right pulley. Will be interesting to find out.
Dave / Believer45
jdemaris
01-09-2004 05:28:27
Even if you do get it off, chances are you won't get it back on with screwing up some dimensions. You need to have the pump off, and have something supporting the bearing shaft where it pokes through the impeller while you press the pulley back on. Otherwise the bearing assembly might start to push further into the housing. And, even if it doesn't, the bearing isn't designed to take the kind of side-pressure you'd put on it by pressing the pulley back on without support.
Tom in Mo.
01-09-2004 18:21:40
 Re: Re: Re: Re: 2010 Gas waterpump pulley in reply to jdemaris, 01-09-2004 05:28:27
Yes, the pump has to come off the engine and the shaft supported. Besides screwing up the impeller shaft dimension in the housing, the shaft/bearing assembly has a small retainer clip through the pump casting and if pressure is put on the shaft without removing this clip the casting will crack and be trash.
jdemaris
01-09-2004 19:22:55
 Re: Re: Re: Re: Re: 2010 Gas waterpump pulley in reply to Tom in Mo., 01-09-2004 18:21:40
Yes, absolutely. And, I think the casting thickness on the 1010 and 2010 pump is the thinnest Deere ever made. I used to do all the bench work at a dealership (waterpumps, injection pumps, hydraulics, etc.). 440s, 1010s, and 2010s were the only pumps that I feared cracking - and that's doing it correctly. Even if the clip comes out okay (which doesn't always happen), it's sometimes wise to heat the housing while pressing if it feels overly tight.
