J d .m smoke from oil filler tube
W D
04-12-2003 18:23:16
Getting smoke from oil filler tube, less then 2 hr. on valae job.
Wayne in Tn.
04-12-2003 19:05:15
 Re: j d .m smoke from oil filler tube in reply to W D, 04-12-2003 18:23:16
WD, Usually this means the rings are shot. Might even need reboring. It is possible that the valve guides needed replacing when the valve job was done. Also you can use the old Chevy umbrella seals,on the valves, even tho the M does not have seals.
