420 Hyd. oil
G.V.J.
04-11-2003 19:01:21
HELP! My 420 seems to gain oil in crank case !! I`ve put new O- rings in Hyd. Pump twice Where is this oil coming from? Is this why people say just use 30 Wt. oil in hyd. system? Thanks for your Help!! PS It seems to gain about a Qt. Thanks Again
Wayne in Tn.
04-12-2003 06:59:54
 Re: 420 Hyd. oil in reply to G.V.J., 04-11-2003 19:01:21
GVJ, The hyd. pump is the only location that will allow oil from the hydraulics to enter the crankcase. There are 2 seals on the pump shaft to prevent this, also you may need to replace the needle bearings or something is worn in the pump housing itself. Changing to 30 weight oil is not the answer to the problem, originally the system was designed for 10w oil.
C Butler
04-13-2003 08:38:24
 Re: Re: 420 Hyd. oil in reply to Wayne in Tn., 04-12-2003 06:59:54
When you next have it apart, check the shaft for a groove worn where the seal rides. Had the same problem with my 40U many years ago. Replaced both the seals & the shaft-no more problems, but be sitting down when the parts man reads you the price on the shaft!
G.V.J.
04-12-2003 08:03:46
Thanks Wayne Well I`ve replaced All the bearings and seals but still seem to be getting oil from there. Guess it is start over.Thanks again for your help
CPeter
04-12-2003 17:09:40
 Re: Re: Re: 420 Hyd. oil in reply to G.V.J., 04-12-2003 08:03:46
Is it possible that the seals are in backwards? Just a thought. Other than that or a damaged seal or bad bearing, there isn't really any way for the pump to leak as I remember it.
CPeter
