Clutch Alignment Tool?
Michael
04-11-2003 13:53:47
Does anyone know where I can find a clutch alignment tool for my JD Model 40T?
Thanks.
Abe
04-12-2003 20:39:28
 Re: Clutch Alignment Tool? in reply to Michael, 04-11-2003 13:53:47
Purchased a universal clutch alignment tool at the local NAPA autoparts store. Works good. You just have to eyeball it a little and turn the input shaft splines so they match up with the driven disk.
Chuck W
04-11-2003 14:32:29
as I recall the IT manual has a pattern for one, you can make a wood down or use a metal pipe and line up, you may even be able to line up by sight. As the tractor goes together use one long bolt to the bellhousing, just snug and you should be able to depress clutch and rotate engine(remove plugs) and make it line up. Its easy if you're on concrete. Take it easy and work it back together...don't get rough with it.
Michael
04-11-2003 14:35:55
 Re: Re: Clutch Alignment Tool? in reply to Chuck W, 04-11-2003 14:32:29
Thanks!
