JOHN DEERE 2010 YEAR 1961
tony shelton
04-10-2003 16:53:40
THREE POINT HITCH LIFTS AND HOLDS FINE WHEN FIRST STARTED BUT WHEN LET DOWN WONT LIFT AGAIN. CAN SHUT OFF TRACTOR FOR 10 MIN AND HITCH WILL LIFT THEN. CAN SOMEONE TELL ME WHATS WRONG AND HOW TO FIX. TOOK TRACTOR TO A REPAIRMAN AND HE PUT A SPRING IN IT AND FILTER AND NEW HYDROLIC FLUID FOR 325 DOLLARS BUT IT STILL ISNT RIGHT.
Elton Fancher
04-12-2003 19:46:06
 Re: JOHN DEERE 2010 YEAR 1961 in reply to tony shelton, 04-10-2003 16:53:40
You need a shop manual. There is an adjustment with a screw and lock nut directly behind the hydraulic oil filler hole that may have a bearing on the problem. The hydraulics on these models are complex and extremely finicky. Elton Fancher
