Ampmeter
Dave
04-10-2003 16:44:18
Is there any difference Between a 12volt Ampmeter and a 6volt?I have put a new voltage regulator on and the Generator is working good but it just wont charge.What am i doing wrong.Its a 1953 JD40 standard.
Clooney (real long post, sorry)
04-10-2003 17:38:42
 Re: Ampmeter in reply to Dave, 04-10-2003 16:44:18
Dave, yes a slight difference but it should still read a charge or discharge.
~There are a few things that can cause a [no charge] on the ammeter.
~The first thing to do is turn the lights on [engine not running] & see if it shows a discharge, if so your ammeter is probably working & you have another problem.
~Next check to see that the ammeter is wired correctly, the big power wire that runs from the starter power stud to the ammeter MUST be the ONLY wire on one ammeter stud. ALL loads including the generator charging wire [regulator BAT wire] MUST go on the other stud. You probably won't be able to see the polarity markings on the ammeter so wire it up & if it reads backwards when you get it working just reverse the wires on the ammeter studs to get it to read correctly.
~If the ammeter is wired correctly try the lights on test again, if it shows a discharge with the lights on MAKE SURE your generator is working & actually charging. If in doubt put a voltmeter across the battery posts with the engine at fast idle & see if you are getting 7.2+ volts [6 volt system] or 13.7+ volts [12 volt system].
~You say your "Generator is working good",,,How did you determine that? Have you tested the charging voltage on the battery side of the regulator? If not maybe your cutout relay in the voltage regulator is not closing when the generator is charging.
~Seeing as you are asking about a 6 or 12 volt ammeter have you converted your tractor to 12 volts? If so are you using a 12 volt generator? Does it have the proper voltage regulator for your battery voltage?
~If your ammeter is wired correctly & your generator is putting out at least 1.5 volts OVER battery voltage & you still don't show a charge on the ammeter suspect a failed ammeter [somewhat common on the older Dubuque's]..
~If you find your problem is really the generator not working use this test procedure for the 420..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..
~ If you have a volt meter just put the positive & negative leads across the battery posts with it running at fast idle. You should show 7+ volts. If not, it isn't charging.
~Leave the voltmeter hooked up & short the [F] post on the generator to the generator case [is it showing above 7.2 volts now?] if so, your generator is probably working & your problem is more than likely a bad regulator, open in the field wire running from the generator [F] post to the regulator [F] terminal, or a bad regulator ground. [try a ground wire from the regulator case to the tractor frame] ..NOTE: the regulator case must be grounded for it to work.
~If it didn't show 7.2+ volts with the [F] post grounded, leave it grounded & run a jumper wire directly from the generator [A] post to the starter big battery terminal stud on the starter [the regulator is very hard to get to on the 420 so it is much easier to use the jumper wire to the starter post]. Does it show 7.2+ volts now? If so your problem is either an open in the wire running between the generator [A] post & the regulator [GEN] terminal, a bad regulator, an open in the wire running from the regulator [BAT] terminal to the [ammeter], or an open in the wire running from the [ammeter] to the battery cable stud on the starter. Use your volt meter & check for battery voltage at the [BAT] terminal of the voltage regulator, [if you don't have battery voltage there, find out why].
~If it still doesn't show a charge, leave the [F] post grounded on the generator, turn the tractor off & disconnect the jumper wire from between the [starter stud] & the generator [A] post. Then remove the generator drive belt & re-connect the jumper wire from the [starter stud] to the generator [A] post,, the generator should start to motor, now un-ground the [F] post & see if the generator picks up speed....If the generator doesn't motor at all, you have a generator problem like- dirty commutator, burnt out armature, stuck brushes, broken wire to the armature brush, bad generator ground, or other internal problem,,,if the generator motors but doesn't slow down with the [F] post grounded, you have field problems like open in the field windings, broken field brush spring, stuck field brush, broken field wire, or other field related problem. NOTE: on that 420, 6 volt generator start it motoring with the [F] post grounded then remove the [F] post ground to see if it speeds up.
~Most people find that printing this test sequence out & taking out to the tractor will help keep things in order.
~If the tractor has been converted from 6 to 12 volts you could have the wrong generator or other change induced problems so post back if you have been converted to 12 volts...
Charles
04-11-2003 08:59:17
 Re: Re: Ampmeter in reply to Clooney (real long post, sorry), 04-10-2003 17:38:42
I believe that Clooney was referring to the fact that a 12 volt system would charge/discharge at half the amps of a 6 volt, all other factors being equal, so the ammeters could have different scales.
John T. is correct in that an ammeter appears as a near-zero resistance in series with the current being measured, so it doesn't "care" what voltage system it's hooked up to.
I think both my 6V (420, 70D) and 12V (50) have stock -20,0,+20 amp scales though.
John T
04-11-2003 09:22:22
 Re: Re: Re: Ampmeter in reply to Charles, 04-11-2003 08:59:17
Hi again Charles, I enjoyed our recent e mail discussions. Thanks for your good info. Like you mentioned, an "IDEAL" ammeter would be ZERO ohms and they are still only a current sensitive current measuring device, not so much concerned with whether a 6 or 8 or 12 or 24 volt battery is causing current to pass through them. It seems some of the later ones desgined for use on 12 volt and high amp alternators have a larger scale maybe even 60 amps or so, while an older one designed for low current output generators, regardless if 6 or 12 volt, only have a 20 to 30 amp scale. Still, whatever voltage it is that causes current to flow through them doesnt matter so long as their voltage withstand rating is not exceeded, and its way larger than 6 or 12 volts and probably would still be the same on either unit. Im not sure what Deere supplies nowadays due to substitutions, but wonder if they supply a diffferent ammeter for 6 or 12 v systems, its probably one or 2 models, like a 20 to 30 amp scale for older tractors (6 or 12 volts) or a larger one with a 30 to 60 for later tractors. HOWEVER, its hard to second guess Deere and all their brilliant marketign techniques, and thay may sell many different ammeters while swearign to customers that and only that is the correct one for your tractor, just as they swear to only use JD oil lol.
Take care Ol John T
F-I-T
04-11-2003 10:54:35
 Re: Re: Re: Re: Ampmeter in reply to John T, 04-11-2003 09:22:22
Charles and John T:
You guys are confusing me again. Are you saying that the same ammeter will read the same if it's in a 6 volt system or a 12 volts system provided the current flow is the same ? Cause that's what I believe.
I was always told that voltmeter measured a potentional difference, and an ammeter a current quantity.
So, if you make an example analogous to plumbing, the voltmeter would measure pressure between say, the internal system pressure and the atmosphere, and the current would be measured by a flowmeter. So, as long as the flowmeter (ammeter) could stand the pressure (voltage) without exploding, the same flow meter could measure a 5 gpm flow in either a 12 psi system or a 5,000 psi system.
I think that's why the identical ammeters are called out whether 6 or 12 volts. If it was voltage dependent it would be measuring Watts.
Frank-in-Tallahassee
70D // 855
John T
04-11-2003 12:44:41
 Re: Re: Re: Re: Re: Ampmeter in reply to F-I-T, 04-11-2003 10:54:35
Yep Thats sure right. An ammeter measures current passing through it. If the current through it remains the same, it will obviously read the same current, regardless if you have 6 or 8 or 12 or 24 volts across its terminals. However, that assuems (for current to read same) the circuit resistance must also change. I equals E divided by R. I think you may be confused in that if the voltage were doubled from 6 to 12 and the load stayed the same, then the current would indeed double. Thats why as long as the indicating scale is the same (although it dont have to be) like 0 to 20 amps, thers no difference in a 6 volt or 12 volt or 24 volt ammeter, because it dont care what voltage is (so long as withstand ratign not exceeded), it measueres the current passign through it NOT THE VOLTAGE.
Clear as mud ???
Post back any more questions, interestign thread we got going here. Ol John T
F-I-T
04-11-2003 13:06:07
 Re: Re: Re: Re: Re: Re: Ampmeter in reply to John T, 04-11-2003 12:44:41
John T:
Nope, I'm not confused about I=E/R. More important is P=I(squared)R. I understand that, too.
I was just saying that when I replied to the first question that an ammeter is an ammeter, be it 6 or 12 volt, the replies to that sounded like voltage was being brought into the mix, and I was certain that didn't matter.
Now, back to what Clooney said, and that was an ammeter would read different in a 6 volt vs. a 12 volt system. There I say no. If a 12 volt generator is putting out 20 amps, then the ammeter will show 20. If the same ammeter is put in a 6volt circuit and the 6volt generator is putting out 20 amps, then that same ammeter will read 20 amps. I know that if the current stays the same and you double the voltage, the wattage doubles. So the 12 volt generator @ 20A is putting out twice as many watts as the 6 volt generator at 20 amps.
So, that's why I said that JD was right when they offered the same ammeter regardless if for a 6 volt or 12 volt system.
An ammeter don't care.
70D // 855
John T (I agree)
04-11-2003 14:43:08
 Re: Re: Re: Re: Re: Re: Re: Ampmeter in reply to F-I-T, 04-11-2003 13:06:07
I still agree with ya Frank, an ammeter is still an ammeter and it reads current flow through it regardless of what electromotive force (voltage, be it 6 or 12 or 24) causes the current to flow through it. Sorry, I dont remember anyone claiming the voltage (6 or 12 v system ammeter) made any difference as to what the current would read, just that maybe the scales might be different like 0 to 20 or 0 to 30 etc????? ?? because on early 6 volt generators that didnt put out much current, a 0 to 20 ammeter would be more readable, while on a later 12 v system using a higher current generator, maybe a 0 to 30 ammeter was preferred????? ?? Good Discussion. John T
F-I-T...Yup !
04-11-2003 15:43:40
 Re: Re: Re: Re: Re: Re: Re: Re: Ampmeter in reply to John T (I agree), 04-11-2003 14:43:08
John T:
Maybe it was my misunderstanding, but in his initial post Dave asked if there was any difference between a 12 volt ammeter and a 6 volts ammeter. When the answer given was, "Yes, there is a difference, but should still show charge/discharge", I posted that that an ammeter is an ammeter is an ammeter.
I just didn't want folks trying to go out and buy something they can't get, like a left-handed monkey wrench, a bucket of steam, or a 6 volt ammeter !
Later !
Frank
Steve - IN
04-11-2003 23:17:16
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Ampmeter in reply to F-I-T...Yup !, 04-11-2003 15:43:40
I want the left handed ammeter to measure the amperage or power levels in AC or RF circuits. Then there can be some difference as phase, frequency, impedance, etc. change. But until somebody finds some "nervous DC" in their old John Deere, any old ammeter is probably good enough. The other factor is that the old gauges seem to flicker over a few amps worth of range anyway -- hardly worth hair splitting.
F-I-T
04-11-2003 07:22:50
Clooney:
When you say there is some differences between a 6V and 12V ammeter, what do you mean ? You lost me there.
For example, JD supplied the AF 2749 R ammeter for the 40/50/60/70/70D/and 80 models, which is certainly a mix of 6 and 12 volt systems. Same ammeter went on to be supplied on 720 gas or diesel, and 730 gas or diesel, electric or starting engine.....
70D // 855
Clooney
04-11-2003 11:59:48
 Re: Re: Re: Ampmeter in reply to F-I-T, 04-11-2003 07:22:50
Frank, for one thing it's a moot point as the 420's were all 6 volt. But even so the ammeters were different from one model to the next across most models way back when. I'm betting you are using the parts CD or at least a late production parts book. You are correct that most ammeters do SUB to the AF-2749R. That right there should tell you something though. With an AF prefix that tells you it's an assembly not just the lone ammeter. ~I don't have a parts book handy where I'm at right now but I believe the original ammeter for the 420 [at least the 40 anyhow] was 1864T.
~As mentioned above it has to do with markings & calibration as some of the 12 volt generators could put out 25+ amps.
F-I-T
04-11-2003 13:27:40
 Re: Re: Re: Re: Ampmeter in reply to Clooney, 04-11-2003 11:59:48
Clooney:
Yeah, but. Dave asked whether there was a difference between a 6 volt ammeter and a 12 volt ammeter. You said there was some difference. I just had never seen a "6" volt vs. "12" volt ammeter. You could buy different scales and ranges, but not different voltages.
If you go to the CD for example, look in the notes for the ammeter of a '50' or '60', and then read the notes for '70D', they all refer to the AF 2749 R as the sub for the previous AB 2568 R. Now if there was a different ammeter called out originally, it might have been for the scale on the gauge, but not because it was 6 volt vs. 12 volt. If some one has that original parts books, I'd sure like to see JD ever offered different black face ammeters for the 6 volt applications vs, the 12 volts applications.
I'm not arguing gauge faces or markings. I'm just saying that the way I read it from you was that there is an difference between a 6 and a 12 volts ammeter, and I say an ammeter don't care. If an old ammeter reads 20 amps and it's correct at that point, it will read 20 amps whether it's 6 or 12 volts, right ?
I understand that if it's a low output 6 volt system like on Dave's 40, they might have selected a more sensitive ammeter, so the +/- scales might have been 10 A, while a 730 diesel system with a big generator and lots of batteries might have used an ammeter with a scale of say +/-20A.
That's all I was questioning.
70D // 855
John T
04-10-2003 17:18:47
Hey Dave, No, an ammeter is a pass through (like a short circuit) current meaasuring device, so it doesnt realy matter if its a 6 or 12 volt battery feedign current through it. It just measures current and isnt really concerned with the batterys voltage.
Did you try to polarize the unit after you installed it??? With the tractor not running, momentarily connect (spark) a wire between the regulators BAT terminal over to the ARM (or GEN) terminal, and you should see a spark, then remove the wire immediately. The ARM post on the generator (larger of the 2 posts out the generator) should be the same electrical point as its connected to the ARM terminal on the VR by a wire assumign its wired correct.
If its a 3 wire VR, (BAT GEN FLD terminals) I guess its wired right??? GEN or ARM terminal wired to the ARM post on the generator, F or Field terminal wired to the gens F post (smaller of the 2) out the generator, and the BAT terminal has to be connected to the non grounded battery terminal eventually, or else it cant charge it. The usual path is a wire from the BAT terminal to the load (non battery) side of the ammeter, and the high (battery) side of the ammeter is fed from the battery, often off the starter post or even direct to the battery. Therefore, if you place a test lamp or a voltmeter on the BAT terminal on the VR it should always be HOT battery voltage, otherwise theres a problem, and even if the gen and VR are working, it cant charge the battery.
I just posted a long winded detailed troubleshooting procedure below on here or over at Rummys JD page to test a generator and VR, so look below on one of these pages and read that post or post back questions if you need more help.
Are you usign a 3 wire or a 4 wire VR???? The 4 wire has a 4th terminal labeled L for load, and if you have that post back, cuz the directions will be a bit different.
I guess its not just a 2 wire cutout relay is it???
Are you still at pos ground?? and is the new VR a positive ground model??? Some work on either polarity, some do not.
The VR has to have a good ground conenction to the steel frame of the generator. Does yours??? Try a jump ground wire to see if that helps in case you're not sure.
Good luck, God Bless the USA, and please pray for the troops.
Ol John T Nordhoff in Indiana
