35 open fan A
matt wagner
04-09-2003 18:23:29
I have a 35 a serial *414200* I bought an original block that was bored .125 over so I put high comp aluminum pistons in it and a cold manifold I just got done repainting it and when I dynoed It! 38Hp normal and 52hp lugging and I noticed that the paint on the head discolored brown but not much! why is it getting so hot there what should I do? what did I do wrong or not! any help would be appreciated! thank you god bless matt wagner
DP
04-09-2003 21:45:57
 Re: 35 open fan A in reply to matt wagner, 04-09-2003 18:23:29
Hi Matt, If you have the orginal block and and upper water pipe yet, you will probably have problems keeping it cool. The early A's had a lot smaller water outlet from the block. Also if I'm correct, you don't have a temp guage to tell you how warm it is running. They just wern't designed for the high compression pistons and manifold. If you run it carefully and break it in, it might get enough better to allow you to play and parade with it, but probably won't be a tractor you can do much work with without heating up, and with no temp guage, thats dangerous. Just my $.02
