JD 50 rod bolt torque
Larry806
04-09-2003 15:44:21
Help I left my IT manual out while I went for part's my son loaned it to his friend What is the torque on the rod bolts Thank you Larry
Larry806
04-09-2003 18:54:11
 Re: JD 50 rod bolt torque in reply to Larry806, 04-09-2003 15:44:21
Thank you Larry
Ben.So.Tex
04-09-2003 18:35:49
My JD service manual call for 75# (if you have the cotter pin type bolt and the cotter pin hole does not line up at the 75# tighten to the next slot.) [Do not lossen the nut if the hole does not line up]/////HEAD call for 104#// now this is for gas,, LP engines might be different, Good luck Ben
AlbertoV05
04-09-2003 17:30:31
Larry806,
The service manual for my 60 calls for 100ft/lbs. and then tighten (if you have to) to get the castellations to line up for the cotter pins.
Al in Iowa
