Drive Disk Remove
Ted
04-08-2003 15:57:44
I'm replacing the clutch facings on a '49 B. The front facing actually came apart and the fragments squeezed the clutch into the engaged position. I've got it taken down to the fixed drive disk and want to remove that so I can replace the rear facing while I'm in there. Right now it is soaking in Liquid Wrench with three arm gear puller tightened up on it. The IT Shop Manual says on the B to remove the disk you can simply thred 1/2 bolts into the two holes and tighten them down - you don't have to use a steering wheel type puller. Is this true? What do the bolts bottom out against, the rear facing? I'm concerned that if you try this method, you'll most certainly damage the rear facing and then be committed to removing the drive disk. I don't want to trap myself in a corner. Any suggestions?
Johan
04-09-2003 07:30:25
 Re: Drive Disk Remove in reply to Ted, 04-08-2003 15:57:44
The bolts bottom out against the pulley. Very effective. Good luck.
