JD air stacks...
Morgan
04-07-2003 19:59:01
I need to replace the air stack on my 46 A. I have seen replacements for sell. My question is-How do you remove the old one and weld the new one on ? Do you just grind the old one off and then HOW do you weld the new one to the cast iron? Thanks for any help you can give ! morgan
Clooney
04-08-2003 03:35:40
 Re: JD air stacks... in reply to Morgan, 04-07-2003 19:59:01
Morgan, you will have to grind the old welds off with a die grinder or other thin disked grinder. You can weld the new one back on with a high nickel content welding rod or even braze it. Even a mig welder will hold it on but the weld won't look very pretty due to the casting.
~Depending on your welder type you might want to talk to your local welding supply shop for the proper rod for your equipment.
Morgan- Thanks
04-08-2003 07:32:53
 Re: Re: JD air stacks... in reply to Clooney, 04-08-2003 03:35:40
I wondered about that, my welder is AC, I will try to find a welding shop to weld the new one on. Thanks-morgan
