I have two answers for you. The first, assuming this was an honest question (doubtful) answer is that these JD gas tractors sometimes have a difficult time restarting when you run them dry. It seems like there is an air bubble in the carb or something. The last time I ran my 3020gas dry, it had to be restarted. Also, once when someone syphoned gas from the tractor (@$$*& thieves) and the small amount of remaining gaas became contaminated, I had to drain and refill the tank. Same thing happened. Pull start the gas 4020 if it wont relite after running the tank dry, ok? Grinding away on the starter, continuously, until the battery weakens is asking for overheating in the starter and associated electrical cables. The second answer: I saw this "Q" on the bashing board and it seemed appropriate for a board that specializes in inflamatory arguments. It belongs over there, as the angry responses it will get are appropriate for the bashing board. HERE, it makes you look like a fool! After all, YOU ran your tractor out of gas and THEN took a poor choice of operating technique in response. Cheer up! At least you DIDN'T forget to put gasoline in the 460!
