Fresh 4020D engine smoking when cold.
Ted/MN
04-07-2003 18:56:57
My '65 4020D Standard now has new JD sleeves and pistons, new bearings, new JD injectors, and fresh valve job. It starts ok, but smells and smokes like it's loading up with fuel until it warms up, then seems fine. (It's definitely smoke from fuel,, not coolant or oil) It has the Roosa DBG pump on it, never had anything done to that. Now part of the problem may be that the valve seats were, after the grind job, at the borderline for replacement, and are recessed to the limits according to the specs. I only put 150-200 hours per year on this tractor so we didn't want to dive too deep in debt on the head. Besides the valves/seats, are there any other places I should be looking for the cause of the smoking? One mechanic suggested it may be the advance in the pump. Another said it was common and to live with it. Any suggestions would be appreciated.
Ted
Tim
04-08-2003 06:26:52
 Re: Fresh 4020D engine smoking when cold. in reply to Ted/MN, 04-07-2003 18:56:57
My 1970 4020D has a Roosa pump (model starts w/ CBC) that was rebuilt just prior to a complete engine overhaul. This tractor blows a lot of white smoke when it's cold (it did before the OH too but I think not as bad), less when warmed up but it only stops smoking white when the pull is hard enough to turn it black. I've been told it would get better as the rings seat, it hasn't after 60 acres of pulling a 5-18 plow. I've also been told it's the fault of this model pump and to live with it unless I want to buy a different pump. I'll watch with interest for more educated opinions but that is my experience for what it's worth.
Tim
Wayne in Pa
04-09-2003 04:38:40
 Re: Re: Fresh 4020D engine smoking when cold. in reply to Tim, 04-08-2003 06:26:52
We have rebult a White 2-70 (pistons slives bearings injectors) and we are seeing the same thing. White smoke at start up then when it has to pull hard it will clear up. I think the 2-70 and the 4020 use the same injectors I dont know about the pump.
