I need help please
T Ely
04-07-2003 16:19:36
Im restoring a 1943 john deere b. when i took it apart it had water in the oil so i cleaned up the cylinder walls so no visable cracks. sent the head out forvalves and mag tested it came back good. I then put it all together after hmmm 30 years of not running. and luckly she fired right up. I ran it for about an hour watching my water i lost about an inch out of the radiator. I didnt think much about it until i went back to the shed to re-fire it and found 3 gallons of water in the oil thats about 1 gallon an hour leak I then disasembled it again I pressure tested the oil sleave that goes through the block and the head found nothing being my first time project i guess im stuck and have no clue what to do next. and info would be helpful
Fuzz
04-08-2003 20:13:13
 Re: i need help please in reply to T Ely, 04-07-2003 16:19:36
Please help me, I'm new to the tractor restoring game. I have a JD model GP serial #22911A. I'm looking for someone to give me info on were to find parts for this tractor.
Dan-CA
04-10-2003 00:19:07
 Re: Re: i need help please in reply to Fuzz, 04-08-2003 20:13:13
I called Detweilers, they advertise in the Green Magazine and Two-Cylinder magazine. I was asking the same thing.
T Ely
04-08-2003 07:08:49
i want to thank you all for your help and i will try these things I do have a broken valve guide at the end but the guy at the shop told me that it wasnt hurting anything. I didnt spay anything on the head gasket because john deere said i didnt need to.I was going to use a copper spray but didnt. I think and i could be wrong that the head gasket was ok. I didnt find any source of water in the cylinders and after i found all the water in the oil i opend up the pet cocks and turned over the flywheel to check for water and she fired right up.I willo check valve guides and rod guides when i get home tonightany other idea would be greatly appreciated
Clooney
04-08-2003 03:41:25
T Ely, as mentioned below the push rod tubes are about the first place to look [very common leak area]. If nothing found there suspect the head gasket [did you use sealer on the gasket & re-torque the head after hot?]
dave
04-07-2003 21:18:05
My rule of thumb for 2 cylinders with water going through is, first check the valve guides, and if that doesn't work check valve guides again. Good luck dave
Kevin
04-07-2003 17:50:37
You can see if the tubes are leaking by taking the cover off the block and use a trouble light and mirror.That much water will be easy to spot.
Will P
04-07-2003 17:05:28
Did the place that did the head replace the push-rod tubes? More than likely it is leaking there if they didn't. Pull off the valve cover. The two center push-rods go threw tubes that are put in the head. Fill it up with water and see if any water starts to run from the push-rod tube holes.
Will P
