JD model B air cleaner
Ron
04-07-2003 12:53:22
Would some kind soul expose my ignorance and answer this question. It only takes 5 hours of running for the oil in my Model B oil bath air cleaner to turn into white slime. If I use the tractor for ten hours the oil becomes white glue. I have owned this tractor for a long time and I am sure it didn't always do this. I expect to be embarrased when I learn the answer, but I can take it :)
Thanks
Ron
Clooney
04-07-2003 13:25:14
 Re: JD model B air cleaner in reply to Ron, 04-07-2003 12:53:22
Ron, it sounds like you are taking in water from somewhere. Have you been using the tractor in blowing snow? If so it's probably sucking in snow. If snow isn't the problem make sure the upper air intake pipe isn't full of water in the bottom. If you are leaving the tractor outside make sure to cover the air intake pipe.
