JD Model 70
Cindy
04-07-2003 11:14:27
My Dad needs to know what planing the head .125 on his Model 70 would do. How much hp would he gain and what fuel would he use? Any other ideas to help gain an edge for pulling?
thanks,
Cindy
Mike Aylward
04-07-2003 16:09:51
 Re: JD Model 70 - in reply to Cindy, 04-07-2003 11:14:27
Cindy, I pull a 60 and am building a 70 puller. I can give you some things to do on your tractor that will help. Email me for more information. Mike
Jack
04-07-2003 12:45:07
Hey Cindi,a good machine man may could take as much as .250 thousanths off w/o hurting anything.It will gain anywhere from 10 to 20 psi per cylinder.Probably lookin at 4-5 hp difference if the valves are in good shape.Good luck,Jack(TN).
G Taylor
04-08-2003 06:41:22
 Re: Re: JD Model 70 - in reply to Jack, 04-07-2003 12:45:07
If the head if off, porting and polishing the valve bowl/seat area,oversize valves and port matching the head to intake and intake to carb. Will gain as much or more power as the compression increase. The LP intake/exhaust manifold system and a conversion from oilbath to dry air filtration should be worth a few HP too. What weight class, tire size and gear is your father pulling with? We are assuming this is a gasoline 70?
