Broken Carb Bold / Pipe
Paul Buchert
04-05-2003 18:17:07
During the winter, water got into the carb bowl, froze and broke the pipe that holds the bowl onto the carb. Any ideas how I can try to fix it? I can get the nut to catch the thread, but not with the gasket in place.
Thanks for you time
Paul from MI
04-05-2003 19:35:39
 Re: Broken Carb Bold / Pipe in reply to Paul Buchert, 04-05-2003 18:17:07
Paul,
This can be repaired, but it must be done right to avoid serious problems later. If that bowl nut comes off or the thread breaks while you are running with a hot engine the fan will blow a lot of gas onto a hot manifold. This isn't cool to say the least. I had one on my B that had been poorly repaired by brazing. I had Doug at Burrey Carburetor in Monroeville, IN repair it. He replaces the whole thread portion of the stem with a new one that is pinned to the remainder of the stem. He did a great job with mine. Cleaning carbs is a fairly easy job, but this repair has to be done right. I'd recommend a professional on this one. Just my opinion.
Paul
Clooney
04-05-2003 18:28:54
Paul, what tractor/carb are you working with?
Paul Buchert
04-06-2003 05:58:39
 Re: Re: Broken Carb Bold / Pipe in reply to Clooney , 04-05-2003 18:28:54
Thanks for the feedback, I will try to contact the folks at Burrey Carb for a professional repair. Paul
