JD 4020 G: Are you sure you have to use a puller ? I have service manual pictures that show those two 1/2" holes are "pusher" holes, not puller holes. Now I've never done a '520', but all I have seen either use a pair of bolts with square nuts to acts as pushers (where the driver is slotted), or just 1/2" bolts if the driver is through threaded. You can use a puller if you want, but those driving disks that are designed to accept those bolts have them screw all the way in and bottom out against the outward facing back of the pulley cavity. Tightening these bolts evenly pushes the driver off of the tapered splines. As I recall, A/B/G/50/60/620 used the slotted driver that used the square nut and bolt to push off, and the 70/720/730 (gas or diesel) used the through threaded holes to use two 1/2" bolts only. From the parts book, it looks like the 520 driver is through threaded for bolts only. When the through threaded holes came out it was a major improvement, and many of the tractors I worked around had a pair of bolts kept in the tool box just for that purpose. I've removed quite a few drivers, and never used a puller. But, please, if I'm wrong let me know. I just don't want the fella looking for a puller if he doesn't need one. Frank-in-Tallahassee 70D // 855
