4020 pto clutch problem
JE
04-04-2003 20:02:45
Recently my 4020 pto lever lost all feeling of resistance. I can not feel it engage or disengage at all and the pto wont work. The pto has not been used in a couple of years. Is there anyway to free it up or pump grease somewhere? I'm triying to avoid having to avoid a costly repair (split tractor) for something so minor.
Tim Southerland
04-06-2003 07:15:40
 Re: 4020 pto clutch problem in reply to JE, 04-04-2003 20:02:45
From what I know about them, one of the guys was correct in checking the shear pin first. This was a common problem with the 4010's.
JE
04-06-2003 13:16:37
 Re: Re: 4020 pto clutch problem in reply to Tim Southerland, 04-06-2003 07:15:40
this shear pin is visible from under the tractor through the inspection plate?
thurlow
04-06-2003 18:04:34
 Re: Re: Re: 4020 pto clutch problem in reply to JE, 04-06-2003 13:16:37
Remove the panel under the steering wheel (directly underneath the ether injector) 3/8 inch cap screw with 9/16 inch head. First check the roll pin where the PTO lever is pinned to horizontal shaft; if moving the lever causes the shaft to rotate, next look inside (where you've removed the panel) to check the linkages there. If vertical shaft is moving, do as G-man suggested (will take two people.....one to move PTO lever and one to shine flashlight up into clutch housing (ENGINE OFF)..... your problems are probably not gonna be this simple and easy to fix, but it's where I would start looking..... .
G-MAN
04-05-2003 14:28:20
Grab a flashlight, pull the inspection cover off the bottom of the clutch housing and check to see what is or isn't moving when the PTO lever is operated. That should narrow the problem down considerably.
Jim B
04-05-2003 05:23:36
JE,on '68 model the pto is engaged by pushing a brg against 3 fingers to put pressure on pto clutch.I hate to tell but it is possible that the end of fingers have been ground off.If so splitting tractor is only way to fix it.Check linkage under dash to be sure it is connected.Jim B
thurlow
04-05-2003 05:20:44
Given the circumstances you've described, I'd first check the linkage(s) for a sheared roll pin..... .
davidval
04-05-2003 01:18:42
older or newer (side console) 4020? ps or syncro?
JE
04-05-2003 01:58:57
 Re: Re: 4020 pto clutch problem in reply to davidval, 04-05-2003 01:18:42
Older (1968), synchronized, standard tread tractor (not row crop)
