Daniel, Congratulations and best wishes to get the old girl up n running again. It sounds like youre well aware of the basics, she needs fuel and compression and fire (at the right time) so youre off to a start anyhow. Heres a few things I will say at this early preliminary phase. First, is it a mag or distributor ignition??? How fast is she cranking over???? Have you tried to pull start it??? Have you checked the compression (may be low from settign, have a stuck valve or stuck rings) Have you tried to squirt some oil into the cylinders to lube the ring seal to raise the compression??? It may just be low on compression from sititng. Did you remove the valve cover to check the valves if the compression was low or non existent????? Has it ever popped or backfired or kicked the flywheel back??? If so, maybe its timed wrong or a plug wire on the wrong terminal. After tryign to start, are the plugs wet or bone dry????? ? If dry, shes not gettign enough gas or the choke isnt actually closing maybe or shes wayyyyy low on compression. Did you adjust the carbs top needle settigns??? (See below) Any gas vapor out the stack when you try to start her??? 1) You say its getting gas, but is the choke butterfly plate closing in acccordance with where you set it externally???? Are the plugs wet or dry after a start attempt??? 2) Have you removed the air cleaners lower bowl to insure its not full of water??? 3) Did you open the carb bowls lower drain cock/plug and see if clean fresh gas flows there at least a 1/16 inch or so stream continuous??? 4) Remove the plugs with their wires attached and sides against frame ground, turn her on and turn her over slowly to verify BOTH are producing a good visible blue and NOT a faint thin wimpy yellow spark. If so, you may have to replace those points you filed with new ones. 5) Is it a Magneto or a distributor??? If a Mag, is it making a loud sharp snap when you rotate the crank??? 6) If the plugs appear fouled or oiled or carboned up, install a fresh set, maybe Autolite 388. 7) Did you try carb adjustments?? The initial settign is 1 3/4 to 2 out for the idle needle and 3/4 to 1 out for the load needle. TRY THAT AND SEE IF IT MAKES ANY DIFFERENCE. I guess if it has gas and clean fresh water free fuel AND COMPRESSION, I would start with fresh plugs and maybe points and see what happens. If she has good fire in time and the plugs are coming out wet and you know shes getitgn gas, try to squirt oil in the plug holes to lube up the ring seal and try her again. Try that and pull start her maybe. She may just need primed up to loosen the rigns and build some compression. Theres lots more that could be said, but post back your preliminary findings, especially the compression and spark, try some oil in the cylinders and a pull start and see what she does. Let us know, post back or e mail [email protected] and we will proceed further. Good Luck n God Bless John T
