JD 40 double front wobbles
Mark
04-04-2003 15:49:57
Should I first suspect the worm gear at the top front of the tractor or perhaps the spindle down on the double narrow front.
The front only seems to wobble badly when I am in fourth gear.
I need help on this one because I am doing it myself.
Thanks,
Mark
Mark
04-05-2003 05:54:43
 Re: JD 40 double front wobbles in reply to Mark, 04-04-2003 15:49:57
This has been very helpful.
I have rebuilt the steering gear on an Allis D12 so I could follow somewhat.
Fortunately this tractor should never see pavement again a I was unloading after purchase and she is now on the farm that should be her grave. She will run a small rototiller for a tree farm and maybe a goper getter.
Thanks again all of you,
Regards,
Mark
Ray
04-04-2003 17:46:49
Jack the front end up,supporting the center,shake
the front wheels by hand,you'll find the problem
pretty quick. (it helps to have the hood and nose
off to see what's Shaking.
Clooney
04-04-2003 16:06:01
Mark, you will have to start by looking at all the possible wear points. You probably have some wear on the 2 pins [studs] on the upper steering shaft that engage the worm, you probably also have some wear on the upper & lower steering shafts where they are connected with that coupling, you probably also have wear on the inner splines in the steering shaft coupling. ~Start with a steering gear adjustment, if that doesn't help then maybe new pins [studs] in the upper steering shaft. If the upper shaft will move very far without moving the lower shaft suspect shaft/spline/coupling wear. Those 40T's need everything tight to go straight down the road without wobble.
~If we can get Wayne to add to this list you will have a lot to look at. [Wayne has been into quite a few of these lately]....
Bill
04-04-2003 17:17:26
 Re: Re: JD 40 double front wobbles in reply to Clooney , 04-04-2003 16:06:01
The early 40s used a single pin to engage the worm like the model M. Later 40s had two pins like the 420. Replacing the pins is fairly simple, new ones are about $21 from JD. The bushing that holds the shaft at the top is probably also worn and a relatively easy fix.
Clooney
04-04-2003 18:20:30
 Re: Re: Re: JD 40 double front wobbles in reply to Bill, 04-04-2003 17:17:26
Bill, even the early 40T used 2 pins. You're probably thinking of the 40-S or U as those only had one pin on the early ones..
Wayne in Tn.
04-04-2003 18:18:01
Mark, since you are calling it a double, narrow front, you must have a (T) The only 40 with one stud in the steering shaft will be the (S) and (U) Your (T) will have two pins. As Clooney said, everything must be tight or you will have wobble in 4th gear. I remember back in the early 60's when I was a teenager, our 40 would wobble going down the road. So that means they were fairly new then and would still do it....
First, with the tractor sitting still and engine off and in gear... grab one of the front tires with both hands, and try to roll it back and forth, if you get motion in the steering support, then you will have to replace the bushings and bearings and thrust washer in it.
Then check the worm gear and pins for wear and possible adjustment of the box, tighten the screw as much as possible without the steering binding, when turning the full range from left to right. Check the bearings in the box and it may be possible to remove some shims from the front cover (3 bolts) If the worm itself is in bad condition, you may have to find a better one at a salvage yard. I don't know if these are still available from Deere or the cost.
Check the coupler on the steering rod, where it connects with the box, there is a special bolt and a woodruff key here. These are noted to be worn out or someone has tried to drill through it and put a regular bolt in it.
After you get everything tight as possible, that is all you can do. If it still wobbles and you plan to do a lot of highway driving, let some air out of one rear tire and add some to the other, this will help keep the slack to one side.
john
04-05-2003 04:35:44
 Re: Re: Re: Re: JD 40 double front wobbles in reply to Wayne in Tn., 04-04-2003 18:18:01
reminds me of and old h ih i grew up on. iwas never in a hurry to get to he field ever morning any way so i drove slow, but on the way home for lunch i drove the tractor with one rear wheel off the side of the road and you could move on then. may you and your family be safe
