3010 Clutch adjustment
mike
04-04-2003 09:20:38
Does anyone know how to adjust the clutch on a 3010 gas? Is this a fairly simple procedure or does it have to be done by a mechanic?
G-MAN
04-04-2003 10:48:18
 Re: 3010 Clutch adjustment in reply to mike, 04-04-2003 09:20:38
If you're talking about the pedal adjustment, to get the correct free travel, it's relatively simple to do. There is a slot on the pedal, and a 1/2 inch bolt running through it. Take the bolt loose and use a hammer to tap the pedal to a different position, then tighten the bolt and check the free travel. It should be a minimum of 3/4 inch with the engine running at 1900 rpm. This is one of those ocassions where an operator's manual would come in real handy.
mike
04-04-2003 11:38:51
 Re: Re: 3010 Clutch adjustment in reply to G-MAN, 04-04-2003 10:48:18
Thanks, will give it a try.
Mike
