47 A and cold weather???
Lyle Pfeifer
01-07-2004 16:06:15
Anybody got any ideas on how to keep this thing running? I have messed with the LOAD and tried to adjust the idel mixture and have it running OK. I stuck cardboard on the front of the radiator to block it off and can manage 140 on the temp gauge. It was a nice warm 20 deg. today. It looked like I was getting carb ice as the carb was frosted. I just put in new 386 AC plugs but one is fouling bad. Has anyone tried to go to the 388 in cold weather? Also seems to help with just a little choke out. Thanks in advance for any ideas. Lyle Pfeifer WA state.
PeteNY
01-07-2004 19:08:03
 Re: 47 A and cold weather??? in reply to Lyle Pfeifer, 01-07-2004 16:06:15
Lyle, Is your carb icing up? We had that problem on our '50 B, and the carb was icing, machined the flanges where it bolts to the manifold and air intake, and the problem was solved. Fairly common problem on the single induction carbs with 2 bolts...also had a buddy who had the cold weather problem on his A, turned out the manifold gasket had a hole. Good luck, Pete
Lyle
01-08-2004 03:27:54
 Re: Re: 47 A and cold weather??? in reply to PeteNY, 01-07-2004 19:08:03
Pete, its icing up. When we had the cold spell 3 days ago, it wasn't but 10 degrees, it ran ok, but today it was about 24 and started to ice. I will look at the gaskets, but I think they are new as I overhauled the carb about 2 years ago. It runs great during the summer, just this cold spell and trying to push snow. Thanks, Lyle
PeteNY
01-08-2004 06:54:24
 Re: Re: Re: 47 A and cold weather??? in reply to Lyle, 01-08-2004 03:27:54
Lyle, Sounds just like ours...you'll probably find that the gaskets look fine, but you may need to take the carb off and either have the flanges machined, or at least, out some sand paper down on a VERY flat surface and carefully sand the surface then check it with a good straight edge.
Tis problem will drive ya nuts! It is common on the Single induction carbs...makes sense...50 plus years of being tightened by only two bolts on the outside kinda makes things stretch and get warped(I have even had this problem on our 70 which has the 4 bolt flange on the dual induction carb)...anyway this problem drove mw nuts, finally Roberts' Carbeurators pointed it out to me, simply putting in a new gasket may not work. Good luck, Pete
Mike M
01-07-2004 18:19:27
I use autolite 388 with good results even in the 4020 gas. Speaking of the 4020 gas it won't run right at all in the cold unless I turn the manifold to warm. Your A will probabaly not run right when it has frost on it,if you are going to use this tractor on a regular basis I would put on shutters and try to find a differant manifold I think they made one called a special in the parts book that would warm up some.Or make some kind of a tin baffle to divert some of the heat from the exhaust to the intake.
old
01-07-2004 17:01:39
You might try one of those tractor heater cabs it would keep the engine warm and you also or maybe just a cover for over the engine area of the tractor
