Model 50 Burning Oil at Slow Idle Only
John Van Valken
04-02-2003 15:50:07
I've got a 1953 model 50 that seems to want to smoke at slow idle speeds. At fast idle it runs fine. The smoke definitly smells like burning oil (instead of a rich mixture).
Any ideas?
John
Clooney
04-03-2003 09:12:45
 Re: Model 50 Burning Oil at Slow Idle Only in reply to John Van Valkenburgh, 04-02-2003 15:50:07
John, if it only happens at a real low idle & not at a normal [factory] idle speed or other engine speeds I would suspect a rich mixture due to carb air flow being too low to meter fuel correctly & a cool combustion chamber. Most 2-cylinder Deere's go pretty rich when idled below 500 RPM's. ~Try turning the idle mixture screws in some when at low idle & see if it clears up [my guess is it will].
~If the smoke is actually blue & not black you might want to suspect a failing ventilator pump
John
04-02-2003 19:02:41
Could be worn intake guides. At idle, intake manifold vacuum is at its maximum. That tends to pull oil vaporsthru the worn valve guides and mix them with the air/fuel mix. Remedy would probably be a new valve guides and valves. Wouldnt hurt to check to see if your crankcase vent isnt restricted also. That would be a simple fix.
