4320 fix up..?
Aron
04-02-2003 07:45:23
Hello, I have a real good 71' JD 4320. It has an original john deere cab on it. I want to remove the cab and make it identical to the cabless 4320s. I need to know the parts this will require and maybe approximated costs. Any help at all is greatly appriciated!!!
4320nut
01-23-2004 19:38:03
 Re: 4320 fix up..? in reply to Aron, 04-02-2003 07:45:23
Keep in mind that the fenders for a 4320 are different than those for a 4020. This is a common mistake that is made.
TD 466
04-03-2003 16:31:28
When you remove the cab you will need a platform, because the original JD cab if it is a hinson cab uses it own platform. Then you will need fenders and the mounting brackets, plus the rockshaft covers, and battery boxes.
jim bob
04-02-2003 14:11:03
remove the cab, buy fenders, get the battery boxes that go under the platform if you don't allready have them re-wire the lights and batteries, maybe add a radio if you want, thats about all it should take on any of the 20 series tractors
Jerry
04-03-2003 09:49:57
 Re: Re: 4320 fix up..? in reply to jim bob, 04-02-2003 14:11:03
shoot.....throw new tires on it and overhaul the engine too !!!!! !!!!! don't forget new seat cushions and gauges !!!!! !
TB SCOTT
04-02-2003 14:01:10
Leave it as is...in the long run it will be worth more as a collectable. :-)
