4020 JD Oil Cooler
MGB
01-07-2004 13:02:56
Can the hydraulic oil cooler be boiled out like the radiator?
MGB
02-06-2004 07:15:42
 Re: 4020 JD Oil Cooler in reply to MGB, 01-07-2004 13:02:56
It is the hydro. oil cooler from in front of the radiator. I had a small oil leak in a line and the cooler vents are clogged with grease/dirt. While I have it out I was just wondering about having it boiled out like a radiator. Since theres no gauge on a 4020 sync. range telling you the temp of the hydro oil, I thought it might be a good idea to make sure the cooler is clean.
jdtractortech
01-07-2004 15:38:23
Yes, MGB you can but you have to make extreamly sure you flush ALL contaminants out before you install it back on the tractor. Why do yo want to do this, did you have a failier in the hyd. system?
Dave
will
01-07-2004 20:02:59
 Re: Re: 4020 JD Oil Cooler in reply to jdtractortech, 01-07-2004 15:38:23
Hydraulic system? The oil cooler on a 4020 cools engine oil not hyd. Right???? or so I thought????? I also am curious as to why the oil cooler would need to be flushed, unless it is stopped up from?????
G-MAN
01-08-2004 07:47:42
 Re: Re: Re: 4020 JD Oil Cooler in reply to will, 01-07-2004 20:02:59
The cooler mounted in front of the radiator cools trans/hydraulic oil. The engine oil cooler is mounted on the RH side of the engine. I've taken oil coolers off of various engines and found various bits of junk that will get wedged in the ends of the tubes, but not one that was completely stopped up. Usually you can just run a piece of brazing rod through the holes to clean them out, and circulate clean solvent through them to flush them.
