A vs. 60 Head Gasket
AlbertoV05
04-01-2003 17:28:45
Is there a difference between a head gasket for an "A" and a 60?
Felpro offers a "full head set" only for the 60, but you can buy just a head gasket for an A by itself!?
Just curious - I bought the Deere one to install, but didn't know if there's a difference in the head gasket for these two models?
Al in Iowa
Drew
04-01-2003 18:56:01
 Re: A vs. 60 Head Gasket in reply to AlbertoV05, 04-01-2003 17:28:45
You can get a Fel-Pro head gasket for an A. Its part # 7744sbx. The gasket from a styled A will work on a 60 (and vise versa). The Fel-Pro gasket is a lot better than the Deere gasket because the Fel-Pro has a full metal sheet on one side whereas the Deere is just composite material with metal fire rings.
AlbertoV05
04-03-2003 09:57:36
 Re: Re: A vs. 60 Head Gasket in reply to Drew, 04-01-2003 18:56:01
Drew,
The Deere #A4626R 60 Head Gasket is (now) a two-sided metal gasket with a composite core.
Al in Iowa
Drew
04-03-2003 10:34:42
 Re: Re: Re: A vs. 60 Head Gasket in reply to AlbertoV05, 04-03-2003 09:57:36
I guess maybe either Deere has updated the gasket or they make a 60 gasket different than an styeled A gasket. I have not seen a new Deere gasket in a couple years, so alot could have changed in that time. I stand corrected on the design of the Deere gasket.
Drew
