JD 4010 trans ?/ price
Farm w/Junk
01-07-2004 12:38:05
Hi my father and I are going to look at a John Deere 4010 and were wondering about price, what to look for and what is wrong with the transmission. It is a gas model with 5000-6000 hours, and the engine smokes some. The rubber is good tin fair. It has a NF end. How much are wide fronts? Are there any problems with these tractors to watch out for? He said the transmission has a problem. He said sometimes this happens and sometimes not. He said you will be driving and go to turn and it just goes straight. He says there�s a little click in the trans when this happens. What would cause this? Is it expensive? Can you bolt a diesel model engine in or do you have to redo a bunch? My dad jokingly offer him $700 and he said sold my dads like we will come take a look at it. We thought that would be a pretty good price. What you all think? Thanks
Matt
John
01-08-2004 04:36:58
 Re: JD 4010 trans ?/ price in reply to Farm w/Junk, 01-07-2004 12:38:05
Matt:
If you guys decide not to buy it, let me know where it's at :) You can do a lot to that tractor for the initial price. A diesel will bolt up but you will have to change quite a few things around. Not impossible but it will take a little work.
John
Mike w J
01-07-2004 18:41:45
We had a 4020 do that years ago it had a broken pinion pin that goes threw the spider gears in the rearend we had to put the whole differential in we used new parts & labor were $8000 but if I had to do it again I would do it myself with good used parts and maybe you would get by for a long time just replacing the failed parts
mgb
01-07-2004 13:09:50
The steering problem is probably caused by the steering valve, not the transmission. I would leave the NF under it and just overhaul the gas engine(if it needs it). If you want a diesel, widefront tractor, you'd be better off to find one for sale and buy it rather than try to convert this one. The price isn't bad though, even if it does have some nasty problems.
Farm w/Junk
01-07-2004 13:14:10
 Re: Re: JD 4010 trans ?/ price in reply to mgb, 01-07-2004 13:09:50
Well from what my dad interpreted from the guy is that you turned the wheel and wheels turned but tractor kept going straight like the differential was ingaged? I was just wondering if the diesel would bolt up instead of overhauling the gas. Thanks
Matt
