John Deere M Question
Don
04-01-2003 16:45:46
I have a John Deere Model M that I rebuilt about a year ago. We re-ringed and honed the cylinders, rebuilt the head,and replaced the governer with a used one. It ran great for about 5 months then all of a sudden while idling, it lost power and will barely pull itself. I have rebuilt the carburator since the float looks to have a pin hole and it still doesn't seem to run right. We have checked compression and the number 1 cylinder is a little lower than the other and improves with oil which leads me to believe the rings aren't seated properly. When we try to start it now, we notice bubbles in the fuel bowl that look to be a back flow that i've been told can possibly be valves not seated properly.I can get it started and it runs decent on half choke but still lacks power. When you close the choke,the motor shuts off. My question:What could be the problem and where do I start. Also, is there anything in the governer that i need to look at as the possible cause of the power loss. It was in pretty good shape but one of the weights seemed a little weaker than the other when it was attached.I've sunk quite a bit into this and want to get it fixed so the wife will allow me to move on to my next project, which is a styled A with a seized engine.
Wayne in Tn.
04-01-2003 19:03:56
 Re: John Deere M Question in reply to Don, 04-01-2003 16:45:46
Don, if it will only run with the choke out, that means it is starving for gas. I would suspect the tank may be plugged where the sediment bowl screws in. Remove the glass and strainer, and open the valve on the bowl. There should be two streams of gas running freely out of the body. If not, then the tank has trash or rust in it. If you have plenty of flow here, you may have a plugged strainer where the fuel line connects to the carb.
russ
04-01-2003 17:57:36
I would check valve clearance, set to recomended clearance. And carb adjustments, not by the book, open them up until it runs right. Also take the drain plug out of the carb and make sure you have good fuel flow. Good luck!
