Clooney adding aux valve to 60
Chris
04-01-2003 15:41:51
Hey clooney the other day we were talking about adding the aux hyd valve to my 60 and using the pump thats on the tractor and just cutting into the pressure line. Can you send me a picture or diagram of how you done that. Thanks Chris
Clooney
04-01-2003 17:57:25
 Re: Clooney adding aux valve to 60 in reply to Chris, 04-01-2003 15:41:51
Chris, sorry I don't have anything with a remote valve on it in my collection at this time to take a picture of, {maybe F-I-T can post a picture of his remote valve set-up so you can see how his is mounted, the only difference will be in where you get your hydraulic pressure from as his is plumbed into his P/T valve outlet}..
~As far as your question on installing the remote spool valve... it is quite simple. Just cut the pressure line at any place between the pump & rear housing in a location you can work at & in a location that allows good hose access to the valve mounting point, then either braze on a couple of pipe thread adapters [or those compression adapters that were talked about in your last post], then run a rubber hydraulic hose from the pump steel line end to the inlet on your remote valve & run a rubber hydraulic hose from the valve return port to the steel line that continues on to the rear housing. All you need to do then is run lines from the valve outlets to your loader or whatever else you want to control with the valve....
F-I-T
04-01-2003 19:39:54
 Re: Re: Clooney adding aux valve to 60 in reply to Clooney , 04-01-2003 17:57:25
third party image
Here's a picture.
It's pretty straight forward. Pressure hose (wheel side on my valve) to inlet, outlet is return to Pow-R-Trol box. I use quick couplers from the side of the box with a AA 5724 R selector valve. Disconnect them to use the 3 point. I have a hydraulic bucket, so I use a two-spool valve.
Frank-in-Tallahassee
70D // 855
RLA
04-02-2003 04:40:02
 Re: Re: Re: Clooney adding aux valve to 60 in reply to F-I-T, 04-01-2003 19:39:54
My setup is pretty much the same as FIT except the way it is plumbed, the loader, the bale spear, and the 3 point hitch can all work at the same time. I also added an extra connection on the back with two ball valves so I can lock the loader in position and use two hydraulic cylinders on a round baler with a hydraulic tie.
